Trouble with cranking Torsion Bars
I wanted to get my front a bit more level looking so about a week ago I jacked up the front a bit to get the tires off the ground and sprayed the bolts with some lubricant. Tried pretty hard to get those bolts to turn but absolutely no luck...thought I was gonna break the damn wrench. Any advice on getting this to work or should I give up on this idea if it is that hard? and just to make sure does anyone know off hand the exact socket size for those bolts?
But honestly those who have done this...should it really be that hard to turn them?
If I remember correctly, it was an 18mm socket, but don't hold me to that. Mine were difficult also but I was able to turn 'em.
Use a breaker bar and soak them in PB Blast before hand and try giving it another whirl. Even if they are rusted very badly, the breaker bar and PB should allow you to adjust them.
Good luck.
Good luck.
