2WD 6in Lift Questions
I am looking to put a 6in suspension lift on my 06 Screw 2WD. Will I be able to run 35x12.50 tires without having to do any trimming? Also, I am in between the Procomp and Fabtech Kits. Is there a difference or is it all preference and I see they both make 2 or 3 kits, what is the difference in the kits? I am not going to be doing any heavy duty off-roading but would still like something that will stand up if I do take it off road.
I would get the fabtech 6" with dirt logic coilovers and a 5" block out back. Both pro comp and fabtech 6" kits will be enough to clear a 35x12.50" tire.
Originally Posted by nooq
I was running the Pro Comp spacer lift, but have recently upgraded to fabtech's DL coilovers. originally i had wished i wouldve went with the fabtech. Pro comp kinda seems pieced together cheaply and it really doesnt return your factory balljoints to their stock locations, at least on a 2wd. Seems like the spindle they include is a little short.
Originally Posted by rawasever299
I second the motion, although i'm pushing 8"+ inches on a 6" lift with 36" tires. Had i to do it over again, 6" Fabtech, but really i would have spent the extra money an gone with a Rize 8" lift.
One More Question: What size blocks do the Fabtech and Procomp lift kits come with? What is the difference with going with 5in blocks in the rear as oppose to AAL? Also, I have a 2.5in Autospring Level kit, will that make a difference when I got to put on the lift kit? Thanks again.
and for your leveling kit, it can be re-used on the basic fabtech lift, but on the pro comp it isnt a good idea to re-use it because you will be stacking spacers and you will put your front factory components in a hella angle. so in reality, if you go with the fabtech and re-use your leveling kit, it will give you roughly 8.5"s up front, this would mean you need a 5" block in the rear and a 2" AAL to get the truck close to level. or go with a new set of leaf springs. Hope this helps.
