more lift
You have a couple of options. You can install 2 inch Daystar coilspring spacers up front. You could install a set of 3.5 inch lift spindles. Or you could install both. Of course, you can easily raise the rear with lift blocks.
No, it would be like having 5" of total lift on the front. Because our trucks have a rake that is 2" higher in the rear than the front, you would only have a 3" lift in the rear. If you want to get a true 2" lift, just put a block in back and then you would have a total of 5" of lift.
