Does a lift void Factory Warranty?
Since I broke my arm I have been writing/submitting warrenties for John Deere and from what I can tell the warrenty is only as good as the person that writes the claim and the dealer that does the warrenty. The best thing to do is talk to your dealer and see what he says. Some will void the entire drive train b/c it put extra stress on these parts but the only way to tell is ask your dealer.
Check out the link, scroll down to "When warrenties may be voided"
http://www.tap1.com/oldsite/Warranty...anty_info.html
on
Originally Posted by crumbrian
I have been told that adding a lift kit such a the 6" fabtech will void the factory warranty... Is this true or is it only partial warranty on those parts affected by a lift?
Thanks.
Thanks.
If you install a lift on your truck and the ball joints wear out prematurely, yes.
Legally, the dealer/manufacturer has to provide proof that the modifications caused the failure in question. Unofficially, it depends on your dealer. Some are more generous with warranty repairs than others. A lot of dealers won't be in a big hurry to work on lifted trucks though, just because they're harder to work on. I don't like having to use a step ladder to climb up in the engine compartment of a truck to fix a driveability problem or do engine work or anything like that.
Originally Posted by chazf150
I thought that was a little steep. Found the ball joints on rock auto.com for 40 bucks each. I can do the labor part. But heard those lower ball joints are b#@! to take apart. I might tackle it myself.
Originally Posted by spinnintires
yea, its kind of high, the alignment is about 70, the parts about 250. and labor about 200, so about 500 is tops i would say, 700 is high
This is going off the subject of this thread.
Spinnintires- Just for the fun of it I put my spacer back on (2.5").B-4 I get the ball joints replaced. And had it alin`d . Noticed some play in the steering. Do you have the same issue. And have you replace your ball joints. If so how long till they went out. Thanks
