Broken Sway Bar End Link (01 4x4)
Broke the pass. side sway bar end link. I have cranked the torsion bars about 4 turns and I'm running 33's...other than that, I don't know what might have caused this. I only have 70K mi. Any ideas?
Anyway, what is the proper procedure & torque specs for replacing these? I'd think it would need to be resting on the tires, but will I have enough room with them on? How do you draw the sway bar back down to where it needs to be? I bought both side replacements from the stealership for $60. They wanted $210 installed.
Thanks guys!!!
Thanks guys!!!
Unless you have the unbroken side disconnected it (the sway bar end) should be pretty much sitting where it needs to be. If it isn't you have additional problems to deal with.
If it is disconnected, you should be able to force it down by hand, it shouldn't be easy, but it should be possible.
