Is fabtech a true 6"
This reason I'm asking is they say you can only run 35's and ranchos kit is 4" and you can run 35's on it as well am I missing something here. also if you set the same truck side by side one w/rancho and one w/fabtech would one be higher than the other or do they sit the same. Trying to pick which lift to buy is driving me insane.
Originally Posted by wandell
It will lift the front 6 inches and the rear 3 or 4 inches.
Originally Posted by butter180
Get the fabtech it clears 37s the tires rub the inside of my flares only at full lock turns over bumps
I'm pretty upset. The shop that did my 6" Fabtech recommended 33s, saying 35s would probably rub without trimming. So, being a rookie, I went with their advice, even though i wanted 35s+.
I do love the lift, though. The front end does sit slightly higher, but I'm fine with that. I just want to go higher now, without doing a body lift. I had a body lift on my previous truck, and it was not a good experience for me.
What do ya'll recommend for a little more lift? I already have 35-37" mudders on my mind, first of all....that should help some, but minimally. Would bigger rims, i.e. 18s or 20s, help? Add a leaf?
FYI, I have a 2WD...I know...I know...why didnt I just get the FX4..
Help a rookie out...
DGNOLA- I have a 6" fab w/5"bl & 315-70/17`s and have very little rubbing. I have a 2wd. Plus I may put my 2.5as back on, to get more front ht. Don,t know what to do in rr. I`ll wait and see how it sits.
WXSCPO-Did you decide to leave your 2.5as on? Can`t wait to see some pics.
Been seeing a lot of black trucks looking very sharp. Wished my was black.
you can get the 37's to fit w/ A LOT of cutting and if you dont mind doing some rubbing.
The right way to do it is the 8" Rize lift if you wanna run some 37's with no cutting. A buddy of mine just did his and its incredible! We pulled up to a f150 w/ a 6" PC lift and ours was much taller.
save your money and go with the rize...you will be doing yourself a favor
So...I guess the right thing to do would be to get 5" blocks for the back, which would level it out some, but not lift it any more. How hard is the job to change the rear blocks?
Then, I guess putting on bigger tires, i.e. 35s, would be next.
Would I be able to fit 37s easier if I installed a 3" body lift with the 6" suspension that I already have? Or would it require just as much trimming?
I can't wait to see pics of the black truck with 5" blocks...same color as mine!
did you not read my post?
I have 35 and i think my tires are too small
