05 F-150 air shocks
+1 on airbags.
They fit between the frame and spring and only work when there is a heavy load. They won't effect the ride when empty and won't break off your shock mounts on a pot hole. Shocks and mounts are designed to stop spring oscillation not hold up a load. Air shocks are always a bad idea.
Originally Posted by fiburns
will air bags raise my truck any? or should I just get a lift kit?
Lift kits usually do not increase weight capacity, actually most do the exact opposite, by using larger softer springs for more articulation of the suspension. Also by lifting, you raise the center of gravity of the truck making it more unstable, a no-no for heavy loading.
Good luck...get some air bags......
PS. if it's too far down check weights and don't exceed your GCVW.
Airbags may reduce the squat of the rear end, but they don't allow you to increase the amount of weight your truck can handle.
-Joe
I knew that's what you meant as I've heard your advice before....
For starters, before installing anything, take the rig over to a truck scale and weigh it with and without the trailer. Roll across the scales, get the weight, then park the trailer in the parking lot and roll the tow vehicle back across the scales. The differences in the numbers will tell you if the axle is near (or over) its limit to begin with. A severe squat is usually a pretty good sign it may be.
FWIW, I had a 300 lb tongue weight on my boat trailer (verified on the local truck scale). The back end squatted 2 inches exactly. For $10 bucks, it reassured me I wasn't overloading anything, and verified that I had a proper balance to the trailer.
-Joe
-Joe
