Sponsored by: CARiD
rear is uneven
Old Jun 7, 2005 | 12:40 AM
03blackf150's Avatar
Rear end of the truck is not level
Hey yall,
i put a djm 4,6 drop on about a year ago i figured the rear end would settle in. but it hasnt the passenger rear side is still higher than the driver side. Im guess its these crappy toxic shocks that ride really bad. Any idea to fix the probs.? Some epople told me its the gas tanks fualt cause its all on the driver side. If this is the case then my 4.6 gets a fuel cell.
Old Jun 12, 2005 | 11:11 PM
Colorado Osprey's Avatar
First remove the shock if you think thats it. Shocks don't do anything other than stop spring oscillation. If they are holding the truck up, they are too long for the truck.
See if you can put the rear tires on some scales. If indeed one side is really heavier then other by any significant amount (300+lbs.), then think about shifting the weight somehow. More likely, the spring was made wrong with one having a different loading capacity than the other. Springs should have been made in pairs, and if it was not, this problem is the result.
I would contact the spring manufacturer and tell them you want a replacement set......
Old Jun 13, 2005 | 08:46 AM
PONY_DRIVER's Avatar
Is it only unlevel with a full tank of gas? Sounds stupid but when I would fill my 97's 30 gallon tank up you could see the truck lean to the left a little (as seen from the rear).
Old Jun 13, 2005 | 09:30 AM
Lets say you have a 30 gallon tank. Full vs. empty thats 6.8 x 30 = 204lbs.
If a truck leans or sags over 200lbs. it is wrong. I weigh more than 250, and it doesn't change my f150's stance.
I would still contact the spring/kit manufacturer and ask for a replacement set. Tell them you waited if they give you any flack, to see if it would settle in, giving them the benifit of the doubt.
Old Jun 13, 2005 | 10:36 AM
Johnny340's Avatar
re-arc the left leaf.
I had the same problem and had the left rear leaf spring re-arced to regain the original shape (1" more arc). I'm sure it's because of the gas tank over time.
Old Jun 13, 2005 | 12:31 PM
Lt_Dusty's Avatar
I have the same problem on a stock suspension. I too thought it was just settling from the gas tank over time. Being the cheapo that I am, I switched springs around. Made absolutley no change. My only other thought is that since I bought it used, it may have been in an accident and torqued the frame, but I haven't diagnosed it any further.
I have read that Ford finds 1/2 in. difference acceptable in a new truck.
Old Jun 15, 2005 | 10:43 AM
iron horse's Avatar
03BLACK,
Was it unlevel before the drop? Or only after the drop? What components did you use in your 4/6 drop? Do you have a rear swaybar?
Old Jun 17, 2005 | 09:46 PM
i fixed it
yea im real **** about looks about stupid lil things like that. i bought a 1inch drop shackle and it fixed it. It probally leaned when i bought it im a fat *** i weigh about 240 so i really didnt notice caus ei had 31 inch procomp muds.. then i lowered it now im really happy. But i did take it about loosened all the bolts drove it around the block to relax everything tightened it back up with the 1inch shackle.. now its perfect ill post a picture of my truck soon..
Old Jun 17, 2005 | 09:48 PM
Djm
DJM kit is really nice BTW im not gonna dog it.. by far one of the best.. New upper and lower front control arms springs.. and rear has a cnotched flip kit. next on my list is lakewood traction bars.. and im personnally gonna box in the frame on the rear of my truck
Old Jun 20, 2005 | 05:22 PM
MDCurtis's Avatar
I had the same problem with my 98 XLT. I played around with the shackle setting to even it out but knowing both sides didn't match bugged me. I finally just took the one that was setting a little low off and had a spring shop to rearch it for me. Basically tell them how much higher or lower you want it and they adjust it in. Cost me $40 but then it was right on the money level.
