Adjusting camber on a '97 4x4
On the Ford IFS, YES! What needs to be done is the bolts on the upper control arm must be removed and replaced with a new cam bolt. On some models, all you need is a quick cam kit. To identify if you need the quick cams or the full cams you need to look at the bolts to see if one side has a cam pressed on the bolt side. If you do replace them your self, you will need to have the truck aligned, or you truck could drive ill, pull, and/or wear tires. Keep in mind when you start playing with the upper control arms, you change ALL the alignment specs.
