wandell, others with Body Lift - how to access spare tire?
is there a gap behind the plate? didn't try that, tried to squeeze it around the side but the angle was wrong there too.
fortunately i didn't have a flat, was just trying to drop it to make putting the hitch on easier.
I'll see if i can find one of those flip-up, hinged holder like the hot-rodders use to access their gas filler, should be pretty cheap.
Thanks for the info.
maybe you could try heatin the guide tube up a little and bend it up to where the hole is i'd say it would still crank at that small of an angle change,then no drillin or anything.or just zip tie it up even with the hole.this just got me to thinkin bout that cause my buddy has a boddy lift and i was gonna make some brackets to raise his bumper up even with the bed and hadn't even thought of that
