SuperCrew
Bed Extender
Old Apr 20, 2000 | 04:06 PM
  #31
skyjet's Avatar
Post
LRM,
The Line-X is the standard black. My Line-X dealer doesn't spray anything but the black. They said that the colored liners fade over time, so with a life time warrantee they stick with the black. I think the black goes well with the gray bed rails.
I plan on getting some kind of cover for the bed sooner or later anyway, but I do like the black.
www.over.to/SuperCrew
2001 F-150 Lariat SuperCrew, Bright Red / Silver Frost, Medium Graphite Leather, 2X4, 5.4, Moonroof, 6 CD Changer, 3.55 Limited Slip, Tow package, Bright Red Lund Nose Shield, Line-X bedliner, Bed Extender.
Old Apr 20, 2000 | 11:45 PM
  #32
SuperCrew's Avatar
Cool
skyjet,
Those pictures on your web site are really great. I now know how easy it will be to hook up the trailer brake controller, and what the LineX will look like. BTW, the dealer said the bed-extender cannot be removed if the tailgate is locked. Is that true?
2001 SuperCrew, 4x4 Lariat, Blue/silver, 5.4L Captains Chairs, 3.55LS, Moon Roof, Bed Extender, everything but the AV system & skid plates.(Ordered: 2/11/00, Build Date: Week of 4/10, Shipped via Rail 4/12, ETA date: April 28)
Planned Mods: Sprayed-On Bedliner-(LineX); Hard Tonneau or Retrax Rolltop cover, Fiberglass Cab steps (Ford) or SS nerf bars; Gibson SS Dual Sport Cat-back system; SuperChip; K&N Air intake kit; Clear back-painted bug-deflector; (& Maybe: SVT Lighting wheels and Michelin Pilot LTX 285.60/HR18 tires.)
Old Jun 12, 2000 | 12:52 AM
  #33
JScharton's Avatar
Post
Just a tip...
As it has been noted, the Bed Extender does come off fairly easily - and is NOT secured when the tailgate is locked.
However...
I've found that a bike lock - one of the coiled vinyl coated steel cable types, preferably - works well. Just loop the cable through the rear tie down and the bed extender. It effectively secures the bed extender - and still allows it to flip/rotate in and out of position.
Old Jun 13, 2000 | 03:44 PM
  #34
CASUPERCREW's Avatar
Post
The extender is secure when the tailgate is closed and locked. It can only be removed while in the extended position. At least on mine anyway...
2001 Supercrew 4x4 XLT Harvest Gold, 5.4L, Bed Extender, 6 disc CD changer, Limited Slip, Keyless Entry...
MODS: K&N filter, Trenz billet grille
FUTURE MODS: Rhino bed liner, exhaust system (Flowmaster or Gibson?), Centerline autodrags w/ BF Goodrich A/T's...
[This message has been edited by CASUPERCREW (edited 06-13-2000).]
Old Jun 13, 2000 | 06:58 PM
  #35
skyjet's Avatar
Post
CASUPERCREW,
If yours looks like this, it can be removed easily with the tailgate opened or closed. I'm leaving mine out until I get a locking cover. Let me know if yours is different.
[This message has been edited by skyjet (edited 06-13-2000).]
Old Jun 14, 2000 | 12:10 AM
  #36
FyrDawg2's Avatar
Exclamation
Skyjet is correct!! I read these posts and went out to check my bed extender (which came with the truck right off of the lot).
It does indeed detach when the tailgate is up & locked, by releasing the locks and 'dropping' the end of the unit onto the bed. (I never knew this! Thanks guys!)
I'm thinking a fix would be to attach a post or bumper to each end of the frame (similar to the existing rubber bumpers) so that the unit cannot be disengaged from its' mount when retracted. What do you think?
Old Jun 14, 2000 | 01:27 AM
  #37
Red face
Get the ketchup out, 'cause I'm eatin' some crow! I went out to check for myself, sure enough, it pops off very easily in the closed position.
I sure have been tooling around with a false sense of security all this time!!! That's what I get for taking the Salesman's word for it without thoroughly inspecting it myself.
Thanks for the heads up, and excuse while I run outside again, in my boxers, to put a LOCK on it!
<A HREF="http://www.geocities.com/casupercrew" TARGET=_blank> </A>
[This message has been edited by CASUPERCREW (edited 06-14-2000).]
Old Jun 14, 2000 | 10:21 AM
  #38
Post
I think the post at each end idea will work! I'm going to have my metal shop friend weld something on for me.
Old Jun 29, 2000 | 02:27 AM
  #39
robnbuf's Avatar
Post
CASUPERCREW...
Did you come up with a solution for preventing your bed extender from being removed with the tailgate up?
Old Jul 1, 2000 | 01:24 AM
  #40
1dj27's Avatar
Angry
Well... Now MY bed extender is sitting in the garage as well. How asinine were the designers?! So much for the convenience I paid for to be able to extend my bed at will.
All the manufacturer had to do was make the two end rails longer - close to the bed when the tailgate is up. It would have pivoted just fine, and couldn't have been shoved down and ripped off.
Don't see any easy fix, other than the cable lock somebody mentioned. Wonder if the factory will come out with a retro kit with longer end rails??
Old Jul 1, 2000 | 04:16 AM
  #41
FyrDawg2's Avatar
Lightbulb
Just thinkin'...
Drill into the tubular frame on each side near the locking pins, screw in a stainless steel bolt or similar type of 'stud' or 'post' that is just shorter than the existing rubber bumpers. Secure it in there with a locknut and some threadlock.
Old Jul 1, 2000 | 11:58 AM
  #42
Post
I am currently using a cable lock for now. I am going to call Amp-Research to alert them of the problem and see if they will send two of the legs with the rubber bumpers. I think if I were to mount these as close to the existing end brackets as possible, with the screw heads pointed towards the outside so a screw driver can't get in there when it's closed, that the problem will be solved.
MODS: K&N filter, Trenz billet grille, Rhino Bed Liner...
FUTURE MODS: exhaust system (Flowmaster or Gibson?), Centerline autodrags or Hellcats w/ BF Goodrich A/T's...
Old Jul 10, 2000 | 09:02 PM
  #43
gunsnrods's Avatar
Post
I am using a plastic coated coiled bicycle cable with a plastic coated Master lock to secure my bend extender. There is enough coil to flop the extender either way. Works for me with no rattles....
