Custom 2006 f150 warn winch
nope... just bolted right up and didnt have to move anything around. when you say winch system do you mean what brand?
we used a 12000 pound warn winch.
I knew it was a warn, and knew it was a 10000 pounder, but warn has soo many winches, didn't know if there was just one.
gators- from the look of the picture in your sig it is hard to tell. i would have to do some research and i find out. most likely no. but that doesnt mean you cant fab up your skid plate to fit around the winch. shoot me some pics under your front bumper with the plate so i can tell ya if my kit would work.
cheers murdered
little low?
i haven't seen the rest of the kits out there but, just wondering, why didn't you built the mount so that the fairlead would be comming out of the bottom grill? it would have been higher, meaning less likely to be swampped in water and mud when you need it. maybe all kits locate the winch where you have it. just wondering. lemme know.
and the reason i set the whinch under the bumper is because, if you look at the pictures it is a very tight fit where it is already. this is a 12000 pound winch though. you could probably stuff a 8000 pounder under there, but whats the point?
cheers murdered
and the reason i set the winch under the bumper is because, if you look at the pictures it is a very tight fit where it is already,it cant go up any farther. this is a 12000 pound winch though. you could probably stuff a 8000 pounder under there, but whats the point?
cheers murdered
