Went To The Track...Again
Meth isn't just for temps - there is also an octane improvement - and I think every boosted application could benefit from it - with proper tuning to take advantage of the reduces temps and increased octane. You, certainly, may benefit less than others.
And if you're already on the ragged edge of what power you're willing to make - then making more power is not the goal.
Note post 13 of this thread.
I'm not against meth or water injection by any means. I personally just don't see where I will benfit from it as you stated above.
I'm not so sure that every boosted application can benefit. If you don't need the octane and your IAT's are at optimal levels then I don't see where there's any benefit. One of the reasons I've never gone this route. I do believe there's a time and place for it. I desired lower IAT's and made it happen with a higher volume intercooling pump. I have a larger heat exchanger on hand now which I will install in place of the Whipple heat exchanger to see if temps fall anymore. I also plan to fabricate a larger intercooler coolant tank. My temps rise 14-16 degrees now with 13psi and a quarter mile run. I would love to see how much of that I can change without a mod that will require custom tuning.
Intercooler heat soak, poor quality fuel, boost levels producing heat not readily managed by the intercooler system, detonation due to any of the above, or a desire to run more timing. These are just some examples of why one would choose meth injection. Of course I would suggest to anyone that you optimize your cooling system first then proceed.
Sorry if it sounded like I was implying that you had temp issues. That wasn't the case.
But for you to say that you wouldn't benefit is where I'm confused.
Ok, you optimized your intercooler, I get that. You're even adding octane booster already, yeah, I understand. SO how would you NOT benefit from even cooler intake temps and even more octane? You're already trying very hard to accomplish the same thing meth does, why wouldn't going 1 step further by actually using meth not help? I'm not saying you should or you have to or that what your doing isn't good - just stating that meth can benefit you, like it does anyone else that likes colder aide and more octane.
Boost is an indication of resistance (backpressure in the intake) to the air being offered to the engine. If you make an exhaust mod and lose boost that means the engine is now able to process more air and thus make more power. The drop in boost should never be mistaken for less stress on the motor. On the contrary VE will go up as will fuel burn.
The Dynatechs feature 1 5/8" primaries which are perfect for building low end torque. They do not produce a drop in torque. Oversized primaries do. The longtubes offered for our trucks with 1 5/8" will usually make more bottom end torque then the stock manifolds.
For grins I monitored my torque to the converter through SCT data logging software. I data logged at the track and measured my torque to the converter. 48lbs sitting in gear at idle (650rpm). At the 3rd yellow I floored it and she made 351lbs of torque at 652rpms in just .12 seconds. Made 406lbs at just 888rpms .22 seconds after my foot hit the floor. I wonder why I struggled to hook up
One of my problems with the Meth injection is the fact I would need to pull fuel out in my tune. Most of this I could probably do with my handheld with the tunes from Troyer as he has opened up the tunes for some adjustments. What bothers me is I'm now relying on the Meth system and if fails for any reason pop goes the motor in a split second. Don't get me wrong I rely on my fuel system for this everyday but with meth it just seems like I'm adding another potential fail point. Perhaps I'm just over thinking it.
Nice work Twinscrewd! Very impressive!. You have an 11-second stock block truck there, and I believe you will prove it once you can hook off the line! Traction will put you into the 11s, I strongly believe that.
You have set the standard for sure. Jack has a good point. I realize your charge temps really are in check and recognize the improvements with your upgrades. And if the PCM is adding timing, you certainly are doing the right thing. I do believe lower charge temps would pick up even more power. I realize it is winter, however, have you considered adding dry ice to the intercooler? A 10 degree drop in charge temp will roughly yield 10 HP. I think you would easily drop that few extra tenths. Just my $.02. FWIW.
Your charge temps are great, I simply would like to see you drop just a few tenths, and make a few solid high 11-second passes. I know your setup is capable of it!
Congratulations on your progress! Keep up the good work man!
LOL @ BROTHERDAVE.
LOL @ BROTHERDAVE.
But kidding aside I have no doubt she could run a 12.0 or 11.9 with traction. The track just sucked. It rained all day Saturday and the sun never really got to the track Sunday to put any heat in it. Not to mention the vehicles on street tires out there doing burnouts My drag slicks still have these marble size ***** of rubber stuck all over them. I'll have to post a pic. Still a fun day. I'm glad RobertP invited me out there. It was nice to go to a track and actually know somebody.
The coolest part was that truck turned it's fastest times ever and rolled the clock to 90,000 miles on the same day.
