Went To The Track...Again
More details to come but I ran a 12.3 @ 110.35 today and backed it up with 2 more runs of the same time and speed. Track was slick though. 60' for this run was 1.83. I can only imagine what I might have run if I could have nailed down a 1.70 like I normally do.
Swapped the Whipple pulley. Made 13psi and added Torco to my 93. As the day wore on track got worse to the point 60' times were up to 1.9's yet my mph remained at 110. I data logged and found the PCM loved the Torco and was adding timing with each run. This helped compensate for the **** poor 60'.
Guys I have no doubt that a 1.7 60' as I have pulled many times before would have put me at 12.0. What I have found with this truck is that a tenth in the 60' cuts .2 to .3 in the quarter.
when i used to go the track alot i found that cold weather helped my mph but hurt my 60 ft. the cold air made the pavement colder so i didn't grip as good, but the cold air made more hp so my mph jumped up.
i quit going when it was cold, i didnt like losing traction much further down the track than i was used to. hitting a wall at 20-30 would stink, hitting it at 60 to 70 could be a trip to the hospitol.
The data logs look really good. She was happy and adding timing.
No sir. No meth. Don't need it. No killer chiller. Just the Whipple HE and a Jabsco pump. My IAT's rose 14-16F on each run from the burn out to the traps, peaking at 106F on one run. The other runs never saw it rise above 100F. Not bad at all. For an octane boost as mentioned above I used Torco. First time I've done that.
