more boost and temperature ambient = upgrade radiators ?.
We'll any real racer/ tuner want use an fmu that is straight up crap, I wouldant run one on my push mower it's basically like a boost a pump I want run that crap either, I only run a proper fuel system period or leave it all factory
Mr. Twinskrewd Ok, thanks for your comments, and I would ask you, my truck is for everyday use, not for competition, but the ambient heat rages, these core radiators 1 3/8 ", is 1 ò 2 rows then enough for me?, maybe in a year or two go to an engine built and 12 to 13 psi maximum, this radiator is the one, and the cost is much lower than the $ 600 or more of the other, and there my concern is, why had not considered, because of its low cost, or the difference against the other.
BS: You claim to beat both. You said in your other thread the EB was catching up and would have passed you, later when its pointed out you say you were going to beat it.
Stop picking my posts apart. This is getting retarded. The point is a bigger pump and bigger injectors are not required. The capacity of the fuel system is there to support 9 PSI or they WOULD include a bigger pump and injectors, or it would be limited to 6 PSI or labeled a TUNER KIT.
So, NOW you concur with the concept of the BAP? And it's OK as long as we are just using code to increase PW to the fuel pump instead of a module that increases the output voltage?
Eco boost don't break the tires loose because first gear in the ford tune keep power down, as does traction control to prevent such a thing.
Drive a stock F150 and a Livernois and tell me the twin turbos still lag and wont spin the tires..
We'll I've drove one brand new on the lot I was going side ways on the road it was strong and I have one at the shop with a livernois tune and it hauls *** and one a buddy had with 3.55 rear. 4 door 4x4 6.5 bed and 20 inch wheels ran 15.0 at 91 in 80 degree heat
I believe the dual core 1 3/8 radiator will be just the ticket for you and keep cost way down. But I would like to hear your response to the questions above. From what I found the Motorcraft part number 6L3Z8005B is the dual core 1 3/8 model. It retails for $477.08 but can be purchased for much less. And if you go with a quality OEM spec aftermarket version it can be had for well under $200. This is the radiator I plan to upgrade to in anticipation of my built motor.
The other radiators mentioned early on that come at high cost will more then do the job. You just have to decide if it's worth it.
Hello Mr. Jason , my engine temperatures at WOT up fast at 220-230 ° F , traveling at 100 mph , but speed more the temperature rises, my relationship A / F at wot this for 11-12 . At the moment I have not circulated much but , the room temperature was about 110 ° F and the air conditioning on as the temperature rises quickly. Motorcraft eFans but I have a switch Direct are both at the same time, traffic does not raise the temperature reaches about 185 ° F , but when I can accelerate and maintain speed , even with the eFans , goes fast and should slow down. I clean the inside of the stock radiator and still the same. I just got a quote of $ 916 rondavisradiators for much money. Vista Pro has a radiator which, according PartsGeek is the part number Part Number: W0133 - 1702384 with 2 " core for $ 220.98 , but I worry that in the image the connections for the transmission oil are on the opposite side . Do not understand how these radiators cost $ 200 and the others are above $ 600 , ok , are 2-3 rows and aluminum all but $ 200 these are so inefficient ? , my doubts . Reische I have a room thermostat to 170 ° F that works great . not like comparing one of these against eg the Saleen , the Fluidyne , etc. . I think I will buy one of these or Spectra 1 7/16 , saving money and I get a great improvement. Regardless of the conditions, do not you think? .
I would definitely try it. Lets say it does what you need for now. If and when you go built it does not do the job you sell the radiator and pick up something else. But I think it will be fine. I have that same thermostat and the single core radiator. I've never seen temps above 198F. But it's 80-90F outside so that makes a difference.
If your temperatures are fine in traffic, that tells me u have a flow problem inside the radiator as it stays cool when going slower but once u are going down the road it don't have enough flow I've seen this many times were people are like I've had it flushed, we'll that don't help swap the radiator u will be fine
IR0NS1N- I did not say I DID have a 14 second truck. I said I had a damn good shot at it. If you state that a stock Ecoboost runs a 15.0, and knowing what I know by how mine performed side by side, then I should be faster than a 15.0 when I feed mine what it's appetite needs. I will upgrade and post graphs and video when I get it done. No problem backing up what I say, and no problem eating crow if I am wrong. But I did leave that particular Ecoboost SCREW behind.
