whipple blower ???
Old Oct 17, 2013 | 10:07 PM
  #31
flux's Avatar
i will call you this weekend crash...didnt have much time to think about it today... my thinking on the 2 valve motor is omly the ease of bolting on a 3.4..
i know the 3valve heads are better,4valve even better but more money...
if i do this my budget would be around $20,000 to $22,000 bones give or take....
like i said i think proweld for the long block im going to over build in case i want more.. or go more to begin with, i have all winter to think about it... one thing to consider to is i live in wisconsin it dosnt get above 80 or 90 degrees
very often here.. i like the ice box and the bigger heat exchanger with fans to..
fabing a mid plate would prob be the way yo go
Old Oct 18, 2013 | 10:07 AM
  #32
javier garcia's Avatar
$20,000 is more than enough dough I think. Just get good forged rod pistons cnc head job blower cams2.3 whipple @ 16-18 psi and I'm positive you will be a happy camper. Transmission upgrade it when ur stock one gives up, and go with at least 4.10 gears. I thinks u can do this with less than 15k.
Old Oct 18, 2013 | 02:11 PM
  #33
twinskrewd's Avatar
I will say anything over 600-650rwhp in one of these trucks will be more then challenging. Cost will be through the roof and every system will require an upgrade. It would be a high 10 or low 11 second ride at the drag strip on slicks but unless you were going to run drag radials on the street your beast will be getting smoked by a lot of less powerful vehicles do to the lack of traction. You will have a very expensive wheel burner. All things to consider. I've mentioned this in other threads but I'll throw it out there for thought here. I make 475rwhp at 1100' on 12.2 psi with 11 degrees of timing. Now just imagine a built motor that doesn't need to be detuned to keep the rods in it running 15-18 degrees of timing. The additional timing can be worth 50+ hp alone. Now optimize your power band with a set of cams designed for a blower and with higher lift. 30hp. And for kicks will go ahead and port the heads. Gonna want a 3.25 or 3.00 pulley to get the boost back up with the flow improvements. Getting the picture? 600rwhp is not hard to get. I believe 600rwhp can be obtained on 12psi with the right cams, heads, built motor, and inlet restrictions removed.
Old Oct 18, 2013 | 03:49 PM
  #34
twinskrewd's Avatar
Originally Posted by Crash!
Don't get me wrong, we can push 12 PSI on a stock engine running pump gas... 93 octane. It is not unrealistic.
That experience was making 478/542 on a 4.6 at 12 PSI. A built, 9:1 forged engine, factory PI heads with swedged plug threads, TR-6s, a ported shroud T-67, and a good, custom fabbed 3" 3-core intercooler. I had a built engine, and could peg a 20 PSI gauge in an instant. But I was not tuned for it. No time to react.
Again, not trying to sway Flux away from the Whipple, we will move forward with one.
Crash, you need to check your notes. Here you said the 478/542 was at 16psi. https://www.f150online.com/forums/su...bocharged.html
Put up or shut up... I wondered when someone would ask me to. I forget there are so many new members since 1999! We are damn good at what we do!
4.6 L. 5-speed, a T-67, first graph on the top is at 8 PSI (Base kit). The second was at 16 PSI (And I can dial in 5 PSI more, as I saw 20 PSI on the guage). At all boost levels on back to back runs, charge temp was 91 degrees!
A/F is 11.5:1, and the power levels at 8 PSI are perfect for stock engines. NO LAG. Now, with the controller (16 PSI) the boost hits so quick and hard you really have to be on the ball, because you will hit the rev-limit in the first 3 gears with my 5-speeds. It happens that fast. I will say this... I WAXED a twin turbo Porsche and TWO Vettes that mashed the LOUD PEDAL when they heard me whine on the HIGHWAY.
Both graphs peak at 4000 RPM.
8 PSI- 388.7 RWHP, and 428.7 RW FT/LBS.
16 PSI- 478.0 RWHP, and 542.9 RW FT/LBS!
Several of us tuned that day, and I made more power than a Terminator Cobra at 16 PSI.
And again here https://www.f150online.com/forums/su...-specific.html
Generally, lag is more prevalent on the 4 bangers. Our V-8s make enough bottom end torque to eliminate any lag. The A/R on the turbos we have used have been .63-.81. The .81 makes loads of power. I ran a .81 on both the 4.6 and the 5.4. My 4.6 pulled all the way to redline... 478/542 was at 16 PSI.
Old Oct 19, 2013 | 11:18 AM
  #35
flux's Avatar
i was thinking, to fab a mid plate to except the the big blower,
could you just adapt the 2.3 plate to make it fit or would a guy have to
fab up a totally new one???? just a thought..
Old Oct 19, 2013 | 03:25 PM
  #36
flux's Avatar
anybody have a pic of the mid plate for the 2.3 3 valve kit???
found a pic of a lightning plate but no 3 valve...
Old Oct 19, 2013 | 03:28 PM
  #37
flux's Avatar
http://www.whipplesuperchargers.com/...sp?ProdID=1236
This is the Lightning upgrade for the 3.4L compressor.
cool.... what is the alum. part off to the right?? dose the mid plate bolt
to the top of it??? its hard to see...
Old Oct 19, 2013 | 08:14 PM
  #38
Ross-FX4's Avatar
What part of the mid-plate do you wanna see?
Old Oct 19, 2013 | 09:32 PM
  #39
flux's Avatar
the top, the side the bottom of the blower fits on...
Old Oct 19, 2013 | 10:27 PM
  #40
flux's Avatar
i think i found the 2 to compare, but i dont know how to post pics...
but thay look very much alike...
Old Oct 20, 2013 | 12:09 PM
  #41
flux's Avatar
heres the 3 valve i found cant find just the plate, but
Old Oct 20, 2013 | 12:17 PM
  #42
flux's Avatar
heres the lightning plate, you can tell they look alot alike
coolant hoses are both in back with a square discharge opening...
bolt holes look the same
Old Oct 20, 2013 | 02:07 PM
  #43
flux's Avatar
That is the piece included in the upgrade kit. Tuner kit only, once again. But JDM has the tune and a list of fuel and air system mods.
The finished product. Midplate included in the kit. The base SHOULD be the same, as it bolts to the Lightning intake. The rise and bolt pattern on the adapter is what will be different. It looks like it increases plenum volume, which is a good thing.
The same link I posted above, although I had that image in my hand two days ago, and believe it or not, have been searching for it since. I am all over this, even when you think I am sleeping... LOL!
http://www.whipplesuperchargers.com/...sp?ProdID=1170
You are going 2 valve aren't you? Now let's move forward. Call me so we can nail down the details and decide who is going to build your engine to start with. We have the blower and fuel/air system nailed down for sure.
no, prob. 3 valve.. thats why im comparing plates
the top is the kit that fits 04 to 08 f150, the bottom is the
plate for the whipple lighting kit with the 2.3....
thay look to be very close..
Old Oct 20, 2013 | 05:25 PM
  #44
Ross-FX4's Avatar
I know the 3.4 uses the 2.3 Lightning inlet elbow with a reducer. This elbow will not fit onto a 3v mid plate.
If you fitted a 3.4 then you need to move the bridge and drive pulley forward 22mm (7/8)
Old Oct 20, 2013 | 06:21 PM
  #45
flux's Avatar
so the 2.3 and 3.4 are the same length?
