Going Built
Thanks to the stock internals 5300 is my 1-2 shift and 5200 for the 2-3. I can only imagine what increasing the shift points by 1300rpm alone would do for track times. I wish there was a calculator for that to give me some idea or someone with experince who could guesstimate.
I hate to be a nitpick **** but here are some videos to feed the ears
Honestly all 3 are good cams, but I would pick up the 127550 over the 127350 even though you lose vct. With the increased horsepower you wont miss the vct. Also the idle will let others know you own something badass. The 127550 cam would be perfect in stock heads shifting at 6500RPM. The 127650 is only needed for stage 3 heads with bigger valves.
All the mustang guys recommend the 1275X0 cams based on N/A or F/I.
Comp Cam 127450
Rpm Range 1500-6700. Lobe Separation 113* Intake Centerline 102*
Duration Intake 264 Exhaust 279.
@.50 Lift Intake 229 Exhaust 240.
Lift Intake .535 Exhaust .555
Comp Cam 127550
Rpm Range 2000-6900. Lobe Separation 113* Intake Centerline 102*
Duration Intake 272 Exhaust 287.
@.50 Lift Intake 237 Exhaust 248.
Lift Intake .547 Exhaust .560
I'm sad to hear a built trans only allows 5300rpm. I thought stock the truck pushes like 5600. I was hoping you'd say 5800 as then a cam on stock block built trans would allow a cam install that'd be useful.
Yea I know that. What I meant was whipple brings the shift points to 4900 to keep the converter happy. Aftermarket tuners bump it up some but not much. I was hoping built trans and verter would let you shift at the stock 5600 or past it
Yes the built trans and converter will allow for a lot more. One of the great things about the converter is it can handle lock up at later speeds and with more power. Stock converter has something like 24sqin of clutch surface. Upgrade converters can have anywhere from 70-100+ sqin.
With less power output at say 8-10psi you could still shift at 5600 and the converter needs to be locked by 68mph. My limiting factor is the powdered rods. I'm scared to push them that hard at this power level. So I shift at 5300rpm which is my peak hp as well.
My thinking is that my truck shifts at 5000 rpm. If I go built trans I can shift at 5600-5800 rpm. Then I can go with maybe the 127350 cam and get a good gain. My rpms are to low for a cam at this point
Yes I will pull the motor and send the heads to MMR and the block will go to P&M Performance a local engine builder. When the heads come back I will install the heads, timing componets, cams, and degree the cams. Then she goes back in the truck. Should be good to 900hp and 8000rpm though I never plan to spin it over 6500.
Man reading this is giving me the itch.
Why did you go "stage 2" heads and not the "3"?
I planned on going with the highest flowing heads and a biggest cam I could and still be practical.
Talking to JDM I would be around 600-650 on pump. That should be good enough on motor. A little direct port dope just in case.
