Going Built
I might start it this weekend
My 40x60 should break ground in 2-3 weeks. I'll have a place to work on my junk where I live so you never know. I already have a set of heads, shortblock, and some h-beam rods. Some pistons, few other misc parts and a little machine work ill be ready to go on the short block.
$965 Machine work, balancing, and short block assembly labor. Will be less if she doesn't need a 20 over bore or line bore.
$1800-2000 Forged internals (depends on which parts I choose) and could be reduced by finding parts for sale cheap.
$320 valve springs 26125-24
$620 cams 127350. Will use 127650 if I do port the heads.
$120 Ford head bolts head gasket kit
$20 oil pan gasket
$200 timing kit
$500-530 Accufab throttle body
$$$ JDM Dyno tune
I already have new coils and plugs in tool box.
Heres an interesting read http://www.fnsweet.com/forums/05-09-...ted-heads.html
Notice the comment from JDM with regards to porting the 3v heads. Same thing Jim Jr told me on the phone last week.
" FRPP heads are a mild port job with stock valves and springs. The 3v heads flow pretty efficiently on their own and porting isnt going to gain much unless you go to a larger valve size and upgrade the valve train. We perform a full CNC race port job on our cylinder heads and upgrade to 1mm oversize valves, high pressure springs, and light weight retainers. This along with some cams will make for some killer power gains. When doing something like this we offer a core on the cylinder heads because of the cost value. The gains are much more worth it than the FRPP heads and if your going to endure that much labor your better off going with a better performing setup, like ours."
The prices from MMR have perked my interest though.
All below stages include disassembly/assembly, Competition valve job and new seals along with the full port and polish
of the intake port, exhaust port and combustion chamber. We Guarantee our head porting to be the best in the business!!
Stage 1 Port and Polish 286 int/203 EX @ .500 $800.00 20hp
Stage 2 Port and Polish 290 int/210 EX @ .500 $900.00 30hp
Stage 3 Port and Polish 306 int/222 EX @ .500 $1000.00 40hp As used by Team MMR
Options:
Upgrade to MMR Stainless Steel Valves (std or 1mm oversize) $349.99
Upgrade to Manley Nextec Spring kit $349.99
Change valve guides to bronze $265.00
Upgrade to Titanium retainers $299.99
Upgrade to Titanium Intake valves (call)
Options:
I hate to be a nitpick **** but here are some videos to feed the ears
Notice the comment on the 127550
Honestly all 3 are good cams, but I would pick up the 127550 over the 127350 even though you lose vct. With the increased horsepower you wont miss the vct. Also the idle will let others know you own something badass. The 127550 cam would be perfect in stock heads shifting at 6500RPM. The 127650 is only needed for stage 3 heads with bigger valves.
All the mustang guys recommend the 1275X0 cams based on N/A or F/I.
Just got done swapping the 127350's for 127550's and picked up 59whp and 40wtq. On pump gas, it makes 705whp and 590wtq.
