Pulled the Whipple off...
going to be wicked....
Watching your build makes me want to go ahead and finish building my engine. Hell even if I leave the heads un-ported for now and just slapped in the short block and cams. Up the boost of course.
I'm having the damnedest time finding what I want in the price range I'm willing to spend. I was going to put an offer on a house today, but someone beat me to the punch yesterday evening...
Was really looking forward buying a house with an attached 7 car garage with an apartment upstairs, and the 30x50 metal building outback.
Wel *****!! I started the truck this evening and she ran beautifully till I spotted the injector on cylinder 8 pouring fuel out. I swapped it out with the injector from cylinder 5 and it slowed the leak considerably. Intrestingly the number 8 injector did not leak when placed on cylinder 5. Guessing I should have replaced O-rings??? Any thoughts? Why would just that one cylinder leak?
Its at the rail. Fuel was gushing down the injector from where the injector slides in the rail When I traded it out with the one from cylinder 5 it slowed to hardly anything.
You might used a little white grease on the o-rings. If that doesn't fix it, new o-rings might be in order. If you still have your old injectors, you might just take an o-ring off one to fix it in the interim, if only one is leaking.
Fuel injector leak resolved at the 11th hour!! Troyer performance bound @ 4a.m. It was an alighnment issue with the rail.
Batn68 I'll make a list of paints and process as soon as I can.
