T-Stat
T-Stat
After a quick search (sitting at the airport getting ready to board), the reviews are mixed on which t-stat to run. I'm on my way home to install the s/c and this may be the last detail to work out. (Yeah right!)
Should I stick with stock, or go 180?
I should be starting the install tomorrow.
I think you need to check out your cooling system. If you're not seeing engine temps within a few degrees of that thermostat, you're not going to see any differences with a colder stat. I'd flush the cooling system and make sure your fan clutch is working.
Also forgot to mention the a/c was on full blast which also robs the cooling of the radiator with the condensor sitting in front of it.
