Whipple Custom CAI (PICS)
#32
Going to find out how well she does this weekend. I have 3 hygrometers. So I'm gonna place one in the box, one close to the box under the hood and one outside. I will do this after driving the truck for a while and letting it sit and idle for about ten minutes. After 10 minutes of idle I'm gonna place the hygrometers in said positions and allow her to run 3 minutes longer and then check readings. I can't wait to see the results.
#34
#36
You have the box sealed, I really don't think that is necessary as once the vehicle is moving the under hood temps will fall drastically. I ran several 4" flexible inlets to the air intake area on both my Lightning and '03 Cobra from the front air damn area which I believe helped supply sufficent cold air to an open AF1 intake.
And I am looking at sometime in June to make the trip to Covington.Just as soon as I return from China.
#37
https://www.f150online.com/forums/me...novi-2000.html
#38
#39
TESTING RESULTS!!! Drove the truck for a total of 14 miles. First 10 were city the last 4 were highway. Pulled in the driveway and never shut her down. I forgot to grab my third hygrometer so I took the two I had and placed them on the tailgate of my Dads Ranger parked in front of my truck for four minutes to obtain an accurate outside temp. Then I popped the hood and set them in place. One lying on top of the MAF as close to the box as possible and the other inside the box. I closed the hood and let her idle for 12 mins them popped the hood removed the airbox cover and the results are beyond my wildest dreams. 51 degrees different. If I were to insulate the box and put a gasket on the lid it would probably be even better. Either way I'm very satisfied!!!!
#40
#42
