New injectors
Old Feb 18, 2011 | 02:34 PM
b2therad's Avatar
New injectors
Where do you guys buy your injectors from? I need some 42lb injectors for my truck because I am getting it dyno-ed this next week. I was offered used ones from Fuel Injection Specialties for $250 which are tested and warrantied, but I was wondering if there might be a decent deal on some new ones. If not, I can always just get the ones that they offer and have them installed at the same time. I have been searching around performance websites, but all I have found were 36 or 39lb.
Old Feb 18, 2011 | 02:45 PM
Windsor's Avatar
The 39 lb. injectors actually flow 42 lbs. Seems FRPP wanted to name it something different to distinguish between EV1 and EV6 series injectors.
Old Feb 18, 2011 | 02:56 PM
b2therad's Avatar
Well the only problem I have with 39s are that the 42s are a direct replacement. The 39s require spacers in order for me to run them.
Old Feb 18, 2011 | 03:43 PM
Windsor's Avatar
Then I would get the 42s. I think the pricing issue is largely a supply and demand issue. I wouldn't think twice about the $250 deal, if their tested and warranted. Cheapest I can find for new is $399.
Old Feb 18, 2011 | 10:04 PM
b2therad's Avatar
I appreciate the responses. Looks like ill just go with the $250 deal then. Cheapest I could find was $350 myself.
Old Feb 20, 2011 | 06:39 AM
Veteran: Army
I'm running the 39#ers, and it's only the EV1 to Ev6 adapters that you need, you could've foud a set of 42#ers for around $150 used...
Old Feb 20, 2011 | 07:06 PM
IR0NS1N's Avatar
I'm running 48lb GT500 injectors for the extra room for growth so I can push the motor towards 500rwhp
Old Feb 20, 2011 | 07:21 PM
rcantu's Avatar
if you want new 39# w adapters you can get them here http://www.buyfordracing.com/shop/pr...roducts_id=731
if you want used 42lbs check out mustang forums like corral.
Old Feb 20, 2011 | 07:48 PM
coobies5's Avatar
check forums.....i got a set with 7k on them for $100 shipped.
Old Feb 20, 2011 | 08:00 PM
b2therad's Avatar
With those 39#'s all I would need would be those adapters for sure? IF that be the case then I will order those. I would like to have brand new injectors, and my tuner recommends 42's. He said 39s would work, but that I would need spacers . I was aware that I would need the adapters so that deal you posted seems like a pretty good one.
Old Feb 20, 2011 | 08:12 PM
rcantu's Avatar
those include adapters so you're set on the fuel side.
Old Feb 20, 2011 | 09:04 PM
b2therad's Avatar
alright sweet. Out of curiousity. Are those what you run?
Old Feb 22, 2011 | 11:15 AM
Veteran: Army
those are the good adapters, they look better once installed than the ones I run do
Old Feb 22, 2011 | 01:51 PM
jbrew's Avatar
RJM has them as well.
http://rjminjectiontech.com/?p=14
Old Feb 22, 2011 | 05:09 PM
Marc Carpenter's Avatar
Got mine from Blue Oval Motorsports in Virginia.
