Losing boost- procharger
I am running 9lbs boost on my procharged f150 and while shifting gears I lose so much power. It takes about 3 or 4 seconds for it to start making boost again while it sort of sputters and feels like there isnt enough fuel getting to the motor fast enough? or maybe it is pumping too much fuel while im shifting? The wideband reads about 12.6 with 9lbs boost
Ford F150 4x4 4.6l 5 speed 3 core intercooled-procharged, true dual flowmasters
The procharger was finished yesterday. The kit came with an alternate fuel pump that jacks up the fuel pressure. And procharger says it doesnt need to be tuned if it is stock maf and injectors. I have a lightning 90mm maf, 42lb injectors, and a 255 fuel pump(not installed yet). I figured I would see how it runs before I put those parts on and have to get it tuned.
Thanks for the help!
Thanks!
on
It is normal to loose a few pounds between shifts because of the rpm change between gears. But it should not sputter. That is a leak. Go over your install and check all the connections to be sure there are no leaks and the clamps are tight. It took me a week to get them all tight enough to not blow off and stop leaking.
You do know that the injectors and MAF and not plug and play? You have to have a tune that has the correct transfer function for that specific MAF and the correct injector settings (slope, offset, etc.) need to also be updated, before you can install them. You would need to get someone to write you a tune that has the updated parameters in order to install those components. Likewise, you would remove the FMU, which would be a device they had you install between your fuel pressure regulator and the return line to the tank.
It does sound like the bypass needs to be tightened up, but iirc the one provided with the Procharger is the Bosch, black one, which is not adjustable. I would think that with a manual trans, it would help a lot to limit the bypass action, either by using one with an adjustable diaphragm or modifying the Bosch.
Discussed here beginning at post # 50:
https://www.f150online.com/forums/su...stalled-4.html
on
This is what came in my kit.
It is adjustable in that you can set how much it opens the valve but even fully closed it leaks. In the past I contacted Procharger about this and they said it was designed that way and that the leaking was normal and it would not change things if it didn't. I chalked that up to Procharger standard response #75 and left it at that. I had a replacement butterfly fabricated and it leaks less but it still leaks. One of these days I will get around to getting one that doesn't leak.
What I have done to reduce pressure loss during shifting.
1- Better bypass valve. Get a bosh/ piston bypass valve or fix the Procharger system.
2- Shift faster: I have a Hurst short throw. My clutch is fully disengaged when the pedal is pushed in 1½ inches.
