Whipple Problem... Need Help
#46
Are you really making 427rwhp at only 8psi or are you at 10psi? Also, what pump are you running. I'm just trying to get all the input I can before choosing a pump set up. That link has the gt 500 pump at $350 where a boost a pump is only $200 -250 depending on which one you get, I think either 30 or 40 amp.
Also, if I am not able to get the used 39# injectors that came from whipple, have we determined if the FMS ones will work or not. I dont want to buy them and have them not work. and there are several people who say they will work, and several who say they wont. Which one is it?
#47
I'll have to scan and post my Dyno charts.
#48
Welcome to the world of hot rodding, sometimes you have to experiment....
That gt-500 is is a DUAL pump unit. You can swap in two 310lph pumps and really have potential for power.
Also people throw around rwhp numbers. Not saying he doesn't have a 427rwhp dyno chart, but his same truck on different dyno could read 410rwhp, on another read 450rwhp. Also every truck is different, one might do 430rwhp and the other with the same mods might do 400rwhp.
#49
Thats what I figured, hey when you get your dyno tune can you let me know what your numbers are. As of right now I am just trying to get my fuel problem fixed, but I would like to know what your numbers are to help me determine if I want to go to the 3.125 or 3" pulley. Is your truck 2 or 4 wheel drive?
#51
#52
#53
So it looks like I have another problem. What does it mean when the RPM's start climbing without me really even pressing on the gas. This usually happens when I'm cuising at about 1500-1800 rpm in town, I will give the truck a little bit of gas but not much (just to stay up to speed) and the rpm's will keep climping untill I let off of the gas but the truck wont get any power. Any ideas?
#54
#55
Lee
#57
I dont think its the tranny cause it doesnt happen a lot.
I dont have any trouble codes
My dad thinks I have a sensor issue, so once I get some injectors I will head down to his shop and see if we can fix the problem. Just trying to get some ideas first.
#58
#59
Ok...
So what you are saying you can be cruising along 40mph, want to get up to 50mph. The rpms quickly jump up to 3k, but you are still going 40mph?
Try and see if you can recreate it at a certain mph. It sounds like a tune issue, like you are going in and out of lock up.
But the thing is, the RPM's are climbing to 3000 and up when they should only be at around 2200 with how much gas I'm giving it. And they will keep climbing even with the throttle in the same spot. So I end up having to take my foot off the throttle to let the RPM's come back down. Then everything goes back to being fine.
The main thing is that the RPM's are climbing way higher then they should and its not giving the truck any power.
