wastegate or boost controller
Old Jan 22, 2008 | 07:23 PM
tj03f150's Avatar
okay so we put the new turbonetics on..
some reason it wont make anymore than 2 psi. the previosu turbo when it worked.... we only saw the same... 2 psi...
im thinking the wastegate could be stuck open... or the boost controller is bad.
the turbo is a turbonetics and it sounds pretty badass..
Old Jan 23, 2008 | 08:06 AM
tj03f150's Avatar
none of you guys have any idea?
Old Jan 23, 2008 | 08:35 AM
built54's Avatar
well the boost controller is probably what you need. is that 2psi at WOT? Are you sure the boost gauge is accurate?
Old Jan 23, 2008 | 08:39 AM
Veteran: Army
could be either one, I'd start with the bypass valve, then the wastegate, then the boost controller...
look at the bright side, @ 2psi you won't have to worry about a forged rotating assembly hope you get it figured out
Old Jan 23, 2008 | 09:00 AM
mrpositraction's Avatar
Are you running an intercooler? Check all the fittings! The wastegate or the blowoff could be bad.
Old Jan 23, 2008 | 10:50 AM
tj03f150's Avatar
it is running an intercooler, everything looks great as far.
no blowoff valve though its got a bosch bypass valve. so there is no spring in it to adjust.
it does have a turbonetics manual boost controller and its adjustable to 5-25psi
but the wastegate may be the weak link here, its a pos ebay wastegate...
Old Jan 23, 2008 | 10:54 AM
Fx4OffRd's Avatar
What psi spring is in the wastegate and are all of your vac lines hooked up correctly? Those are 2 other possibilities.
Old Jan 23, 2008 | 11:00 AM
tj03f150's Avatar
its got an 11.15 spring in it, as far as i know all the vac lines are hooked up right cuz i had teh shop do that for me and this is a regular thing for them..
but.. they could have made a mistake too... truck is still at the shop at the moment..
the first thin the guy at the shop said was 'well, u might have a bad boost controller'
so they wanna bypass that and see what happens.. see if it builds boost or not..
Old Jan 23, 2008 | 11:23 AM
How do you have a bad manual boost controller? Aren't they pretty simple?
I would pressure test your intercooler with the piping and your intake. I just helped a buddy with his, turned out he got 3 bad turbos in a row. These were not small nor cheap turbos. I don't remember the name but they were 92mm I think. He couldn't make much more than a couple pounds of boost. We checked everything, boost controller, blow off, wastegat, intake (found a small leak, but wasn't the culprit). The turbo weren't properly built or whatever and coupled with the high (to high actually) oil pressure the turbo was seeing we ended up with the 4th turbo working. Now, he is tuning and getting ready for 15 psi. This is on a Trans Am.
Old Jan 23, 2008 | 11:56 AM
dart_440's Avatar
Turbo
Make sure the manifold pressure is to the middle hole of the wastegate, the boost controller is hooked to the top of the WG and manifold pressure is to the other side of your boost controller.
Could be a leaky diaphram on your wg.. Also just clamp the other side of the bov when its trying to boost and see if that fixes it.
If its the turbo, look at the wheel and see if it has a wobble. When I was running a TV series 88mm a couple years ago I backfired through on and it didn't like that!
Manual boost controllers only add boost over top of what the spring should do. Adding pressure to the top of the WG makes the spring seem stronger and the boost will increase.
They probably hooked the WG up wrong.. Those ebay WG's are cheap but i've seen them actually work.
Old Jan 23, 2008 | 12:10 PM
tj03f150's Avatar
thank you for all the responses
we'll bypass the boost controller first and then see what we can do as far as adjusting the wastegate.
seems to me after reading more on other forums that wastegates are wastegates they do all the same just some handle more than others.
so basically getting stuck open is probably not something its going to do.. especially since its spring loaded.
so hopefully its a minor issue, i cant afford a new wastegate.. this project has gone way over budget.. and definitely stressful
Old Jan 23, 2008 | 12:34 PM
Well, good luck, keep us posted.
Old Jan 23, 2008 | 12:56 PM
tj03f150's Avatar
okay.... now were making too much boost.. were making 10-12...
thats too much for my 2 piece composite upper intake right on a 4.2l v6 f150 right?
Old Jan 23, 2008 | 02:03 PM
What did you change?
Old Jan 23, 2008 | 02:35 PM
tj03f150's Avatar
i didnt change anything myself but im pretty sure the shop adjusted the wastegate some, so hopefully they just reverse whatever they did to get me below 10psi.. then i'll feel much better about everything.
