low dyno numbers?
low dyno numbers?
I finally got the truck back on the dyno yesterday,with 39 lb. injectors and a 3 1/8 pulley it put down 382 HP and 435 TQ.
With the truck also having longtube headers,this number is low to me?
I was expecting over 400 HP and at aleast 450+ on TQ. I will call Troyer sometime in the future and see what he thinks,I have no ideas on why the numbers are so low to what everbody else is putting down. With the truck finally having a tune, I'm just going to drive it and enjoy the power it has for the time being.
If you search the forum for members with the Whipple and go from their start to their end dyno numbers you will see that 400rwhp is not as simple and easy to achieve as some think.
The tune does make a big difference. There are also compromises which affect the slope of your HP and TQ curves, where you may make a few more top end HP, but suffer from decreased midrange, etc. Many tuners talk about area under the curve, and this is what I'm referring to.
The weather conditions also have an effect on your #s, so don't sweat it too bad right now. I'll bet your truck is a blast to drive now, isn't it?
How was your A/F ratio, and did the curve begin to go lean at higher RPMs? That's what happened to mine, and I replaced the stock fuel pump. The higher PSI and the bigger injectors required more fuel above 4500 RPM.
FX4Matt also has headers, as well as dual Maggie exhaust, e-fans, and air intake on top of his 8 PSI. That's about $1000 or so more and he SHOULD have 410 RWHP. I'm glad his truck is back together, and I assume that it's running like a bat out of hell!
I'm going for a new full exhaust treatment and e-fans next time around, but not til I can afford it.
Enjoy.
Lee
Enjoy.
Lee
It was tuned on a dynojet,here is the graph:
I'm having a blast with the truck and after spending more money than I want to add up,I'm just gonna drive it and enjoy it for a while.Sometime in the future I will might drive the truck up to virginia and see what troyer can do,but that can wait for another day.
