new turbo
Old Jan 10, 2007 | 05:13 PM
BLACKBEAST02's Avatar
new turbo
so im gettin a turbo for my 2002 f150 around may and was just seeing what i should do to prepare and make sure my engines ready for boost. im either goin to a pro turbo kits or sts. only gona go with 5-6 pounds of boost till my engines ready for it in a couple of years. sorry i didnt put this in earlyier i have a 5 inch lift with 35's 4.10 gears a posi then air intake exhuast and a edge that im going to sell and get a custom chip for soon. also is it bad for me to run pullies with a turbo set up?
Old Jan 10, 2007 | 07:05 PM
Jordan not Mike's Avatar
Save your dough and forget the chip until you get the turbo setup installed...you'll need a custom tune anyways.
If you're only looking to run 6psi or so, I'd save your money and get the STS.
But if you plan on upping the boost later on, then the Pro Turbo kit ought to be better for higher boost levels, methinks.
Just make sure your engine is in good shape.
I'd look into a valve body or separator plate for your tranny, like from Factory Tech. I'd also look into an additional tranny cooler.
IMHO a larger MAF (from a Lightning), 255L/hr fuel pump and larger injectors (42# is a good choice) are good ideas. IMHO install everything at once, then get it tuned on a dyno.
Old Jan 10, 2007 | 09:59 PM
i have the valve body and ill look into the tranny cooler. How exactly would i make sure my engiones in good shape?
Old Jan 11, 2007 | 05:48 PM
adt's Avatar
adt
Compression check or leak down test. You don't want to throw a turbo on an engine that's about ready to lose a ring.
Old Jan 11, 2007 | 05:50 PM
how and where do i do that at?
Old Jan 11, 2007 | 07:06 PM
adt's Avatar
adt
I believe any local shop can do it. It doesn't have to be a high performance shop. You shouldn't have a problem finding a place.
Old Jan 11, 2007 | 11:19 PM
skidmarkracing's Avatar
Where are you located at? The pro turbo kits were built from my trucks. I have been installing them since the conception. The STS is a very nice system, but is also limited in what you plan on doing with it. If a motor upgrade is in the plan, then I would go pro-turbo. If you need pics just go to www.turbof150.com. If you have any questions please ask and I will answer the best that I can
Old Jan 12, 2007 | 05:21 PM
im located in Sacramento California. Im really leaning toward the pro kit because i have a lifted truck and every once in a while do take it wheeling and just dont like the idea of a turbo rite there like the sts system
Old Jan 12, 2007 | 07:31 PM
You could have Sal at PSP tune it at Mike Dunn's annual dyno tuning day...Mike's up near San Jose.
Old Jan 12, 2007 | 08:11 PM
BlueScrew4.6's Avatar
On all stock internals plus mods listed below, how safe would the STS system be on an 04+ 4.6L engine? I don't want to make my truck do mach 9, just looking for a SAFE power increase. I've been eyeing them lately and Uncle Sam is about to shoot me some serious cash, so I've been considering it. Opinions wanted.
