Kenne Bell has stopped producing S/C for 5.4 2v- any suggestions?
Old Jan 11, 2007 | 08:33 PM
ABE's Avatar
ABE
I was ready to purchase a supercharger from Kenne Bell for my '04 4x4Expedition, but when I called they told me that they have discontinued all superchargers for trucks/suv's. I am trying to avoid purchasing a take-off harley because I have been told that I will run into wiring harness issues. Does anyone have a suggestion for a new supercharger to help with towing? Whipple also does not make one for the '04 expi with the 2v 5.4l, so other suggestions would help.
Old Jan 11, 2007 | 08:54 PM
built54's Avatar
You will have no wiring harness issues...
Old Jan 11, 2007 | 09:00 PM
ABE's Avatar
ABE
I have been told that the wiring harness' are different enough between the f-150 and the expedition that I would need to find someone to modify the harness. I tried checking with two local ford dealerships, and they were no help. Will a harness from an f-150 work with my expi 4wd? That has been my hurdle.
Old Jan 11, 2007 | 09:04 PM
built54's Avatar
just get harness with the take off unit you buy, that is what i did. Plugs right in your vehicle
Old Jan 12, 2007 | 09:50 AM
brahmus's Avatar
L swap!! Not a real big deal, but well worth the effort!!!
Old Jan 12, 2007 | 11:03 AM
ABE's Avatar
ABE
Has anyone with an expedition made the swap? I have been told that the swap with another f-150 is pretty straight forward, but there are enough differences with the expedition that it creates problems. I just want to avoid putting a couple grand into something that may not work.
Old Jan 12, 2007 | 11:07 AM
brahmus's Avatar
I don't see it being a problem. What would not work? There are a few that have done the swap. And I have done one in a F250 also.
Old Jan 12, 2007 | 01:17 PM
Jordan not Mike's Avatar
I've read a few posts on other forums where Expy owners have done the swap without issue.
They had Mike Dunn help them, you can touch base with him to be sure.
http://www.madenterprise.com/F150.htm
Old Jan 12, 2007 | 05:24 PM
built54's Avatar
same truck from the doors up, no different.
Old Jan 12, 2007 | 08:06 PM
ABE's Avatar
ABE
Ok, so if I can get past the wiring issue, can anyone tell me the main differences between the harley/lightning set-ups. Would one application be better than the other?
As always, thanks.
Old Jan 12, 2007 | 09:38 PM
brahmus's Avatar
Color and the Harley upper blower pulley is bigger, therefore creating less boost in stock form. That doesn't matter as you can make up for it will a lower pulley anyway. They are the same animal and neither one is better than the other, other than color, as some Harley's came Black.
Old Jan 13, 2007 | 08:37 AM
ABE's Avatar
ABE
Thank you.
Old Jan 13, 2007 | 02:03 PM
SCOTTE`screw's Avatar
doesnt TROYER still carry the m90 charger for our trucks?
Old Jan 14, 2007 | 12:02 PM
madferraristi's Avatar
Even if he does, the M-90 is still too small a displacement unit for a 5.4. Go with the Lightning H/D swap, it's an M-112.
