Question about removing rear blocks on a 4x4...
Old Mar 11, 2011 | 04:24 PM
VEECON's Avatar
i have a '10 screw f150 4x4 and im looking to lower the rear to level it with the front. do i just need to remove the rear blocks or do i need shackles or both? im not too familiar with lowering trucks so i would appreciate everyone's help. thanks!
Old Mar 11, 2011 | 09:22 PM
fine_style150's Avatar
my buddy offered to lower mine, he said best way about going into this was 2" drop shackles, leave the blocks
Old Mar 11, 2011 | 09:42 PM
greencrew's Avatar
You can remove the blocks. It's easy. Just remove the Ubolts and lift the truck by the springs, one side at a time. You will need to purchase new Ubolts and nuts.
Old Mar 12, 2011 | 09:01 AM
greencrew's Avatar
You'll fine more details here: What do i need for my 4x4 to sit like a 2wd
Old Mar 14, 2011 | 08:51 PM
VEECON's Avatar
so i can either remove the rear blocks and change the U bolts to the 2wd or just buy 2" drop shackles and keep the rear blocks?
Old Mar 14, 2011 | 10:43 PM
pretty much from what i saw in the thread, had forgotten greencrew had dropped his, saw the thread awhile ago, he knows what he's doin!
or do both and get a 3" drop
Old Mar 14, 2011 | 11:21 PM
coobies5's Avatar
just get 2wd u-bolts if you decide to get rid of the block.
but, if you do shackles, you will not touch your u-bolts at all.
Old Mar 15, 2011 | 01:05 AM
VEECON's Avatar
is one way better than the other?
Old Mar 15, 2011 | 01:16 AM
coobies5's Avatar
your lift block is more then likely only 1" tall
and shackles usually offer you 1-2" of drop. just depends on how much you want to bring it down.
