Go low
Old Mar 8, 2010 | 03:50 AM
migdaddy's Avatar
Go low
I wanna go lower with the truck. Not really wanting to spend $400 on a kit. Whats the most cost efficient way to go lower, but still maintain a quality ride?
Old Mar 8, 2010 | 04:11 AM
OGTerror's Avatar
Air down
Old Mar 8, 2010 | 08:43 AM
hangers and spindles wont affect your ride at this point, and you already have 20" wheels so spindles wont be an issue.
biggest thing is get a quality shock that can handle the reconfigured suspension.
also if you're looking to not break the bank buy your stuff used.
Old Mar 8, 2010 | 12:55 PM
jsvo5695's Avatar
How much drop are you wanting? I think that would be a good place to start.
Old Mar 10, 2010 | 04:24 PM
migdaddy's Avatar
ive got 2" rear drop shackles that make it almost perfectly leveled. Im thinkin 2/4. That would make everything sit nice and flush, and not be mexi'd out.
Old Mar 10, 2010 | 08:35 PM
jsvo5695's Avatar
You could always buy 2" springs in front and hangers for the rear. You wouldn't need the shackle since you already have them. That would give you the 2/4 you are looking for and it would be on the cheap!! just don't forget to factor in the price of the alignment kit and the alignment for the front.
Old Mar 10, 2010 | 09:53 PM
TI_F150BLKSCREW's Avatar
OH MAN...Here come the why you be hating posts! Bombs Away!
Old Mar 11, 2010 | 05:01 AM
Veteran: Army
I've got a set of 3 inch drop coils, I'd consider selling you
Old Mar 11, 2010 | 03:59 PM
migdaddy's Avatar
Springs vs coils...
Old Mar 11, 2010 | 05:57 PM
jsvo5695's Avatar
Springs vs coils...
They are the same part....
Old Mar 12, 2010 | 02:48 PM
same thing different name, it is a coil spring.
However just "spring" could mean leaf spring, but i believe they were both talking about coil springs.
Old Mar 12, 2010 | 04:09 PM
Slammed97F150's Avatar
my Grandpa had a saying..."Same ****, Different Smell" hahahaha
Old Mar 15, 2010 | 02:26 AM
hlbbig69's Avatar
Hey here is an option for the fron look at part # 25001 bell tech It is a +1 _-3 for one purchase you will have all the variables. If you don't like it you have the option of raising it up or down more with no parts cost involved if you bu the springs you are pretty much done unless you cut them which changes the design of the coil and will affect you ride quality. Remeber the strut is designed to replace your old strut and you can drop it 2" and still get it aligned if you go 3" then you need to make mods to the front lower control arms its a 3/8 inch notch to compensate for the lack of stock adjustment already there for the stock alignment set up. You can go to bell tech .com and look up the part 25001 and it will give you the same instruction in a PDF file. That way you know what you are gettting into before you buy it Hope this helps
Mark
Springs vs coils...
Old Mar 16, 2010 | 05:05 AM
migdaddy's Avatar
im buying a used mcgaughy's kit. 2" Front Coils Springs 4" Shackle & Hanger Kit. Then ill buy new shocks if needed.
Old Mar 18, 2010 | 11:07 PM
you will need new shocks, so go ahead and make room in your budget for them
