supercrew subs
Old Nov 28, 2001 | 09:50 PM
SCREW4X4's Avatar
supercrew subs
here are some pics of my sub install in my 01 screw.
i used 3 JL 10W6 powered by a directed 1100d.
then 4 mb quart door speakers powered by a directed 500.
the box is made from 3/4 mdf and fiberglass. it is also ported using a rectangle port.
Old Nov 29, 2001 | 07:44 AM
Robdude30's Avatar
Thumbs up
Great looking install!
Old Nov 29, 2001 | 09:38 AM
Norm's Avatar
Very nice! Good job.
Old Nov 30, 2001 | 12:00 AM
sundog7's Avatar
Very nice. Deep bass and a lower back massage as well!! Where did you hide the amps?
Old Dec 2, 2001 | 02:24 AM
Nodrive55's Avatar
Nice, Very Nice
Excellent instal on the 3 subs...
Just got mine back from a local electronics store "Good Guys".
They swore up and down that it could not be done...
So for now got MTX 4 channel 200w Amp..
Sony Xplode deck
and (4) 2 way JL Audio...
My friend came over tonight and gave me an 8" Bazooka tube.
hooked it up to the rear channel.
But after looking at your setup....changes are coming.
thanks..
Late...
Old Dec 2, 2001 | 02:27 AM
Nodrive55's Avatar
Question...
Is that a custom made panel?
does it stick out any more that OEM?
Did you HAVE TO remove the smaller fold down panels. I noticed that they are no longer there?
Late...
Old Dec 3, 2001 | 08:16 PM
SCREW4X4's Avatar
thanks for all of the compliments...both amps are tucked under the rear seats. the lower half of the panel is custom made from 1/2 mdf with 1/4 inch masonite the top half is part of the stock one it is cut just below where the clips snap it into the body.
i will try to post some pics of another one in my friends screw. we used one 10 kicker L7 behind the passenger side rear seat.
Old Dec 3, 2001 | 09:12 PM
CCarrara's Avatar
Screw,
L:ooks great, hows it sound? Any muffleing from the seats?
Old Dec 4, 2001 | 07:02 AM
HI SCREW's Avatar
SCREW4X4, super professional looking install!! How much clearance do you have between the back of the magnets and the wall of the cab. I looked at the jack compartment on my SCrew and there isn't much depth there. The JL 10W6's you have are about the same depth as the Polk Momo MM100 I just ordered and I was hoping to do an install similar to yours. I'd love to get as much details on your setup as you are willing to give. Please post pics if/when you get them.
Mahalo From Hawaii
Old Dec 4, 2001 | 07:02 PM
Dscrew's Avatar
Nice install!! One ? Why did you install all 3 speakers to oneside instead of in the middle or any other way. Do you have any pics before the face was put on
Old Dec 5, 2001 | 09:07 PM
Derek Ringer's Avatar
I too would like to see a pic of the "pre face: of the box. Post 'em if ya got 'em!!
Old Dec 7, 2001 | 01:27 AM
Sboggey's Avatar
Question Question about sub size
One question- I am doing the exact same thing to my 01 supercrew but am using two Illusion Audio ND-10 subs instead of JL's. Are you sure those are tens, its hard to believe for two reasons, first of all, the amounf of air space back there is limited even when you do all you can and make the box as big as possible with glass and all even for two subs, and second, JL 10's arent shallow enough to mount without having trouble. Oh yeah, there is just not enough room for three tens, two tens is pushing it. I believe that you have 3 8's in there, correct me if im wrong, but if I am wrong you would be the first in history to ever cram more than one 10 back there. Just curious. Also, a question about your box, how far across the back did you extend it, and what did you use to follow the countour of the floor?
Later
Old Dec 7, 2001 | 11:46 AM
Robdude30's Avatar
You may have seen this from the other post;
https://www.f150online.com/forums/sh...threadid=55627
Here is a .36 cu.ft. box for a single 8" sub that I have in my SCrew:
I believe you could get 3 10" subs back there if you did it right.
Old Dec 7, 2001 | 11:50 AM
skidmarkracing's Avatar
I am running two cerwin vega HED 12's in my screw. With the box done I have 1.1 cubic foot per sub. It is all in how you lay the glass. I have pics of it at www.f150world.com/skidmarkracing I hope that the name of the other site is not gonna cause problems
Old Dec 9, 2001 | 12:15 PM
Nodrive55's Avatar
Hey Skidmark...
the link to those pics does not work...
Those will be cool to see.
