Whining Noise comming from speaker or amp?
I have a custom box I made with a 12 inch L5 and a 800 watt sony amp the head unit is also a sony. I have a high pitch whine that comes from the unit during startup and last for about 15 minutes before it slowly goes away or you cant hear it much anymore. I noticed when I give my truck gas or acceleration sometimes it makes it worse but not all the time. Any suggestions??
Engine whine is really common, make sure that you buy good quality RCA cables, not ****ty radio shack stuff. Another thing that causes the whine is when you run your RCAs next to your power wire for your amps. Run the power wire on the other side of your truck and it should eliminate your problem.
Hello guys, I live in northern Kentucky but it has been making this noise regardless of outside temperature but the sound seems to go away 30-60 minutes after driving wither that or my ears get used to the sound. I sanded my grounds and checked them and still have the noise! I believe I am now lost also on the RCA cables I do have high quality cables I do believe! Thanks for your help guys any more suggestions welcome!
