4 12" Sundown Audio Subs 2002 scab
Box is Approx. 1.85 net per Sub not including internal bracing, sub displacement, or port displacement. Port is 90 sq.
I will be running a Sundown 2000D @ 1ohm. Sundown 100.4 for the mids. 2 sets of RE Audio XXX 6.5's will be in the door pods.
2 runs of 1/0 and Mechman 280 amp alt. 2 batts in rear.
144 sq ft. of Dynamat through out.
Subs Up, Port Up this thing Hammers! I currently have a 4 channel MTX (used for old system) rated at 560 total power. 280 to the subs wired @ 4 ohms. Back window wall needs reinforced with some 1/4" angle to keep from flexing. Hums the back window really bad unless it is open. Gets Louder. I guarantee that this thing is in the 140+ now!
I am just finishing the Metal frame that will hold the amps, distribution of 1/0 and the box.Then it is on to installing the Alternator and the second run of 1/0 plus all the batteries, fuses and connections. I will shoot some more pics when I get a chance.
