speaker size
If I remember all of the posts correctly the front and back are 6 X 8.
97 F-150,4.6, Reg Cab, Flareside, Air Aid Kit, TransGo Shift Kit,
Superchips, Gibson Single Cat Back, ******* Bed Cover,
EGR Bug Shield, XL Full Length Running Boards,
Hellwig Rear Sway Bar, Hellwig 2500# Overload Springs
the '97 and newer are 5X7 in the doors, not 6X8...or at least my '97 was that way and so is my '99 SD. The '93 I had was 6.5 in the doors and 6X8 in the rear. I would recomend Boston Acustics speakers for the doors and JL audio subs(IMHO).
1999 F250 SuperDuty, XLT, PSD, supercab, shortbox, 4X4offroad, 3.73 limitedslip, 4R100 with PTO, Grey Rhino-liner, Retrax retractible hardtop, GVWR=8800, TC=13800, Lariat wheels, 295/75/16 BFG AT, power TT mirrors, Clarion CD/DSP, soundstream/PPI amps, JL/Boston speakers, and...
No, 97 and up use 6x8 but a 5x7 will fit in the hole.
Although when I tried to put a 5x7 in mine it fit but with a very small gap on the sides.
Also see thread "Pioneer TS6813/TS6815"
99 XLT 5.4L reg cab 4x2 120" Wheelbase 4 wheel disc brakes/ABS 5 star larait style wheels Toreador Red/Silver 3.55 gears 255/70/16 OWL Delta toolbox
Eclipse 5340 cd player
Memphis ARCS50 component speakers w/tweeters mounted flush in the door panels (excellent sound)powered by a Sherwood 35x2 RMS amp
Jensen 50x2 RMS for the 2 Audiobahn AWC10 subs
Looking for reasonably priced used running boards
54regcab@duesouth.net in Columbia SC
Maverick...
Don't limit yourself to just 5x7/6x8 speakers...the selection of speakers in this size isn't exactly the greatest! I just upgraded the entire sound system in my truck and I decided that I wanted to go with 6.5 inch Infinity Kappas. I used some speaker adapter plates that allow you to mount a 5.25 or a 6.5 inch speaker in a 5x7/6x8 opening. They're basically a piece of plastic in the shape of a 5x7/6x8 speaker with a cutout for a 5.25 inch speaker (if you're using 6.5 inch speakers, you have to do a little trimming) and they work really well. I found these at http://www.autotoys.com if you're interested in them.
Matt
99 F150 X-Cab 4x4 SB, 5.4L V8, Deep Wedgewood Blue/Dark Graphite, ORP, 3.73 LS, Tow Pkg, Captain's Chairs, AIRAID, Luvernve Stainless Nerf Bars, Lund Frontrunner bug deflector, Lund Eclipse taillight covers, Lund Eclipse side rear window shades,
Sony Mobile ES CDX-C7850 head unit, Sony Mobile ES XDP-U50D DSP, Sony MDX-65 MiniDisc changer, Rockford Fosgate Punch 600a5 amp, Infinity Kappa 62.1i's in the rear and Kappa 63.1i's in the front, 2 Rockford Fosgate 8" Punch XLC subs under the rear seat in sealed boxes.
Soon to be added: RamAir styled hood to replace my hail-damaged stock hood.
[This message has been edited by MattT (edited 10-22-1999).]
Matt
Alright, i saw the 1988 Ford speaker size, and i'll assume that the '89 is a 6x8 also, if not let me know. Also if someone could explain to me in plain english, how i could upgrade my sound system, from the original system, just so you know i'm 16 and lookin for you a good sound
1989 Ford F-150 xlt, 2 speakers in the door
My 89 has 6" up front. And no-speakers in the rear. from 1987-1991, Ford DID NOT put rear speakers in the f-series. They did in the bronco. My 93 has 6.5" up front and the usual 6x8's in the rear
Thanks!
1993 F-150 302/e4od/355 Limited slip. dual exhuast w/o mufflers,2 1/4" pipes with Echo Tips, headers, accel plugs/wires(8.6mm)/rotor/cap, hypertech powermodule,5% dark tint. Alpine cd player and Pioneer speakers. I need to get it Dyno Tested and qtr mile times. And someday Ill get picks!!!!!!!!!
1989 F-150 XLT 4x4 302/aod true duals with turbo mufflers, 30X9.50" wild country tires, 3:55 gears w/LS(want after market LS for front) 3" SuperLift would be nice too!
Future SuperDuty owner: But I have it the sheet filled:
F-350 SuperCab Longbed, 4x4, offroad pkg. Powerstroke(Duh!) Auto, 3:73Ls Oxford White with grey bench and VERY dark tinted windows. Maybe someday I can afford 33x12.50 BFG's Mud Terrain! Whatcha Think?
Thanks!
