2 channel amp with dual subbox??
Old Jan 4, 2009 | 07:26 PM
J.Paul's Avatar
My question is did I make a mistake buying a two channel amp for dual sub box?Im thinking running parrelel to each channel.being in stereo mode how do I get subs to move equally.?
Old Jan 4, 2009 | 09:37 PM
Impact9's Avatar
You don't need stereo for subs. That's why they make mono-channel amps. Since you have a 2 channel amp see if you can bridge the outputs in your owners manual. The owners manual normally will give you a diagram to show what I am talking about. Then your subs will work together and not against each other. Plus you should be able to pull more power out of your amp provided it's of descent quality.
Old Jan 4, 2009 | 10:18 PM
hen23's Avatar
What is the pre-out setup on your headunit? You need to buy a y-splitter for your RCA cables. Theyll move equally regardless, so long as there is one gain control and a single input signal.
Old Jan 4, 2009 | 10:42 PM
J.Paul's Avatar
the deck is 600.$ jvc dvd receiver with moniter(kw-avx810),amp is massive rs 25,with two massive rw10 stage2.
Old Jan 4, 2009 | 11:56 PM
Impact9's Avatar
massive rs 25
Number of Channels: 2
Output Power (12.5 volts), 4ohms @ rated THD: 25Wrms/Ch
Output Power (12.5 volts), 2ohms: 65Wrms/Ch
Output Power (12.5 volts), driven into 1ohm: 150Wrms/Ch
Maximum Power into 4ohms Bridge: 300Watts
That amp is severely under powered for those subs. The RW10 is rated 400W RMS DVC 4 Ohm sub and your amp at best is going to give them 65w RMS. You really need a bigger amp to get even close to their potential.
Old Jan 5, 2009 | 01:19 AM
J.Paul's Avatar
Its a funny thing,I saw same set up,and h.s the fricken thing is LOUD.bUT i DO REALIZE THIS.THANKS
Old Jan 5, 2009 | 07:41 AM
hen23's Avatar
Whats the voice coil arrangement on those subs? That matters more than power handling, ect. If you can get a final load of 2 ohms then you can give each sub 150 watts, assuming those specs are correct.
Old Jan 5, 2009 | 01:58 PM
J.Paul's Avatar
dvc 4ohm speakers
Old Jan 6, 2009 | 03:15 AM
Low_e_Red's Avatar
Ok first of all, lets start over here. Yes, you are underpowering the woofers but oh well, its not a huge deal.
Second, I need you to rewire the drivers to a series parallel arrangement. (Wire the - on VC1 to the + on VC2. Then run the VC1+ and VC2- to the amp. Wire it ++ and -- with the other sub. Then follow the directions at the amp to bridge the sub across the 2 channels.
If this doesnt make anysense email me and Ill see if theres something I can ship ya to help you understand a bit better.
Old Jan 6, 2009 | 11:33 PM
J.Paul's Avatar
I got them done by pro..Parallel and then series is what he did and it sounds really nice in there.Got them done today,but im a newbie in the audio world.
