rockford fosgate shallow mount
Originally Posted by marcolarco52
well i have heard them in the store sounded pretty descent...aint it killing you to wait 2 week for install lol
I just installed a single P3SD210 running at 4ohms bridge using an RF 301s (300 watts RMS) in a sealed enclosure (.75 cu ft) . I went with the 2Ohm DVCs so I could bridge it to 4 Ohms and get the most from my amp. Considering its small package I'm pretty impressed with it. It won't give you that hard driving earth shaking punch that two 10's would but it's excellent low end fill and if you want to boom it can hit relatively low. If what you're looking for is some nice punch to accent your mids and highs you'll be in hog heaven.
I have 80hz and above going to my full range door speakers and 125 Hz and below going to my RF 10". It blends nicely but to be honest could really benifit from a 6.5" driver in the mix. But then I don't have my doors amplified by anything other than the deck so a little more juice may do the trick too.
I can't tell you how long it actually takes, but a big warning sheet was in the top of the box of my P3SD210. It specifically stated that the woofer chassis and materials are designed to require a break-in period to achieve optimal performance. The sheet claimed that 24-48hrs of normal use is required before optimal sound is achieved. I noticed a discernable difference after the first day, but it also coincided with me properly setting the gains.
The SHORT answer to your question, according to RF, is normal use is all that is required to break in the sub.
I have the 12 in my SD and it sounds pretty good. I have it in a sealed box behind the seat that a little over one cubic foot of air space, and it sounds pretty good. I'm running 400 watts to it and inside the truck you can feel it pretty good. Two might have been better with such a giant cab, but it works for me cause I could still mount the amps and crosovers behind the seat too. In the back seat you can really feel it and it rattles stuff in the cupholders but its not really like that in the front. As soon as you get outside of the truck you can't even really tell its there unless the doors are open or the windows are down. But I think that is kind of a good thing.
P.S. - Just kidding. I'm young, dumb, and full of... hormones. I like my stuff loud. But then again, I probably won't be able to hear by the time I'm 30. As for breaking in the subs, I was told 10 hours of lighter use (varying the volumes, but never really cranking it up real loud, so that it's not just beating at one level the entire time), but I'm sure 24 hours couldn't hurt. Notice: when I said "10 hours of use", I mean using it for 10 hours, not just having it installed for 10 hours before you crank it up.
Originally Posted by GrifN
Yo' sh*t's WEAK, son! This is UNACCEPTABLE!! You might as well have a midget in the back seat beating on a trashcan if you can't hear your subs outside your car. What a disgrace...
So long as you're running them with clean power, you can 'bump' them all you want. The 'break-in' period doesn't mean "Don't listen too loudly or you'll blow them". It just means that the suspension is stiff from being all new material and therefore will not move as much air (which is why they don't achieve "optimum performance") If you bought a 300WRMS sub. Run it at a clean 300-400WRMS all you want. Nothing's going to happen. If you would like to loosen up the suspension a bit faster though, wire them to a 50W plate amp so they're at Xmax and run them free-air for a bit. Don't get crazy with this, though. Free-air is a whole different ballpark, so you can start bottoming the sub out quick if you give it too much.
Originally Posted by HEC*
I have 2 of them 12" and can not find someone to make a box for them. Everyone says it wont fit under the seats.....
