factory sub upgrade
factory sub upgrade
hey guys i have a 2004 lariat super crew. it has the audiophile set up with the factory sub under rear seat. i was wanting to upgrade just the subwoofer
does anyone know the output of the factory amp and the sub's ohm rating? or am i better off just replacing the whole deal??? (i like how clean the factory look is though)
ty sparky
ty sparky
ty sparky
ty sparky
Are you still using the Audiophile enclosure for the new sub/amp combo? Or not? I am considering using the stock enclosure and changing out the amp /sub. since I have a amp laying around doing nothing!
If you have the factory sub then you wont need a Line Out Converter. I have the audiophile system, or had, wanted to keep my factory head unit and tapped directly into the HU's signal output to factory amp with a set rca's. I will post pics tomorrow and get the wire colors of the factory signal wires.
On the other hand, I would recommend replacing the stock subwoofer box because its plastic for one, and poorly built. Mine split open on the front. Try just a single 10 box to go right where the stock one did, or if you want to spend a little extra get the dual 10's.
