Right amp for subs
Right amp for subs
Hey would this amp be okay to use for running 2 image dynamics 8 inch subs rated a handling 50-300 rms? Bartak advised me that i should use my 600 watt RF amp to push my components and to get a mono amp for the two subs. Here is the amp http://cgi.ebay.com/ebaymotors/ws/eB...MEWA%3AIT&rd=1
and here are the subs
http://imagedynamicsusa.com/tech_pag...type=sub&id=id
Thanks for the help.
I figure the max rms output would be 300 each. I dont want to be anywhere near that so would this one work out.
http://www.millionbuy.com/diad34004.html or this one
http://www.millionbuy.com/diad34002.html
One is a 4 channel and the other one is a two channel but both have 400 rms.
Thanks again
Thanks again
What?? Pushing your subs at there RMS wattage with clean power isnt going to hurt anything. Most subs can over thier rated power, and the ID subs you have will just laugh at 350 watts-so-read on.
Those D3's reminded me of the D3600.1. Underrated 600watts rms at 1 ohm (around 700 watts actually) Solid azz good amp. Rob Zeff designed(founder of Zapco-some of the best amps) You can get new ones on eBay for 220 bucks. Diamond makes good amps, I would take one of those amps in a second.
Yep, the D3 600.1 is a Diamond Audio amp.
http://diamondaudio.com/products/ind...&line=3&model= Scroll to the bottom
16 gauge will work fine for your component speakers
