09 f150 5.4 chattering noise
Old 09-21-2018, 06:57 PM
jrcll58's Avatar
I have a 09 f150 5.4 76,000 miles, replaced with oem ford parts , the cam phasers, the variable timing seloniods, new timing chain and tensioners, and installed a melling high volume oil pump, truck idles smooth runs great, no fault codes, even contacted from youtube fordtechmakuloco, he said try using 10-40 oil, still have the chattering noise when climbing a hill , .....any suggestions ?
Old 09-21-2018, 07:19 PM
Spark Knock?
Old 09-21-2018, 10:43 PM
Does it go away if you use premium gas? If it's a 4wd, what about in 4wd?
Old 09-22-2018, 10:06 AM
jrcll58's Avatar
I think your on to something there, it doesn`t chatter when in 4wd, so I`m guessing it might be vacuum related ?
Old 09-22-2018, 01:44 PM
Yep, it's your IWE's grinding. Read the following thread from our Articles and How-To's forum:
https://www.f150online.com/forums/ar...then-some.html
Old 09-23-2018, 08:34 AM
jrcll58's Avatar
Great info !...thank you
Old 09-23-2018, 11:50 PM
jrcll58's Avatar
so the noise that I hear , the best way to describe it is that of a heat shield on your exhaust coming loose and vibrating and chattering, my 4wd will engage, so I take it that I`m losing vacuum that keeps in 2wd and the sound I hear is it trying to engage ?
Old 09-24-2018, 10:14 AM
That is probably the issue if the noise goes away in 4wd. The linked thread will help you troubleshoot it.
Quick Reply: 09 f150 5.4 chattering noise
