2010 Ford F150 blower motor not running at any speed.
I have a 2010 Ford F150 Lariat 5.4L v8 super cab and one afternoon i started the truck up and the ac would not come on. I popped the hood and turn the key to on with the ac off and the clutch would spin, then i would turn on the ac and it would engage. I also watched it while the engine is running and it would engage and disengage like it should when i hit the button. So i thought it may be the blower motor. I checked all the fuses in the box under the hood and in the passenger floor panel. Swapped the relays with ones i knew were good with the blower motor relay and that didnt work. I pulled the motor out and hooked some jumper wires to it to see if it was good. It turned over when i hooked the 12v wires to the termials. The fan doesnt run at any speed but when i check voltage at the motor harness it reads 12volts.....I plan on changing the resistor next because it is the only thing left. Is there another inline thermal fuse or breaker that is not in either one of the fuse panels that i am missing? Looking for help, it seems like an easy fix but i am lost.
on
For the 2010, like any previous Ford, a manual climate control had a blower resistor while the electronic automatic climate control did not, it has an electronic module called, among other things, the "Blower Speed Control" module.
You have to be specific about which version you have in order to get the correct guidance.
If you have the EATC and you have 12V when back-probing BOTH motor terminals when it should be running, then the BSC module isn't operating, either because it is defective, the EATC isn't controlling it properly, or the ground circuit for the BSC is open. There's nothing else it could be as there are no relays or fuses that can cause that particular set of readings.
Ok, so i ordered a new blower speed control module(not resistor). Before i would not get any blower action at all from any speed and i verified that the ac clutch engages by turning on the key and spinning the clutch freely then turn on the ac and it locks in also while running just no air movement. Now i have the new blower speed module and installed it. Now i get high speed blower air all the time. I can not adjust it and also the ac will not engage now and i dont understand why. Nothing changed except the new speed control module i installed. When i have time i will remove the new speed control module to see if it reverts back to what i had before. I am lost as to why all the sudden now my ac compressor is not engaging.....
Blower moter
mine isn't working either does for a couple seconds then nothing, I've replaced the blower fan and the module still nothing...help!
![Exclamation](https://www.f150online.com/forums/images/icons/icon4.gif)
Jose Guerrero / rolleronariver / Douglas1 / Paul J Pappas (and anyone else replying to this 2-year old thread) ...
HINT/TIP: Put your vehicle information (year, model, cab, trim, engine, wheelbase, _x4 drive, mileage, modifications, etc., etc.) in your signature -OR- provide it in your posting(s).
Edit Signature
AND as projectSHO89 mentioned ...
![](http://www.gdmjoe.com/icons/lightbulb.gif)
Edit Signature
Hi there PojectSHO89, I hope this message finds you.
I've got a 2010 F-150 5.4 V8 Super Crew Lariat just like in the post on this thread. You're info above has really been the most useful thing I can find on the internet.
I've checked my fuses, relays, installed a new BSC, and installed a new Blower Motor.
I've got voltage at my blower-motor-plug (about 2.5 volts), but the blower motor will not blow. The climate controls are working and I can hear the vent doors engage and move for the different settings.
Do you have any tips for me on this?
Does the ETAC push 12V to the blower motor no matter the speed? Could the low voltage be my problem?
Thanks!
Jared
2010 F150 Lariat fan works for a few minutes after startup then works intermittently
So I don’t see very many fixes in this forum so I am posting what fixed my A/C blower issue. First I swapped relay 3&4 under the hood (no change), replaced the resistor (no change), finally I replaced the blower motor itself. So far it has been working as intended.
Just one other thing I used OEM parts from Ford expensive but apparently worth the cost. $134 for the resistor & $394 for the blower motor.
