Drip drip drip went the water
I've read about the computer module issues when it rains.
Mine will lock & unlock erratically, try to start even though the key isn't in the ignition, give me a door chime when I open the door even though the key is removed.
So I have to disconnect the battery when it's raining and I get out. I have confirmed water on what I assume is the computer module, the one with the fuses on the front of it right?
My question is, where is the water getting in. I have laid for an hour in the rain in the drivers footwell looking up into the mass of wiring and other stuff, I can't tell where it's leaking.
Is is there somewhere I can silicone caulk, maybe under the hood somewhere or around the windshield rubber gasket.
I have read that a new windshield has fixed the problem for some people and for others that wasn't the problem.
Thats a moot point anyway. I can't afford a new windshield or another old truck right now.
Thank you.
Thank you.
The only new issue is the transmission slipping when I first start.
That article doesn't apply to a 97, it has a mechanical odometer.
Check the transmission fluid, it may be low. If it's dark and/or smells burnt, you have an internal problem. A fluid change may help, or it may make it worse. If you change it, drop the pan and drain the torque converter to get almost all the old fluid out.
