lack of ac cooling
Old 08-21-2017, 11:10 PM
zxlacxky's Avatar
lack of ac cooling
2005 f-150 4.6 engine
Old 08-21-2017, 11:28 PM
glc is online now
Come on, you have to give us more that that.
Old 08-21-2017, 11:49 PM
zxlacxky's Avatar
lack of ac cooling
2005 f150 4.6 engine. ac line past fixed orifice is very cold while high pressure line is very hot. Is this normal?
Old 08-21-2017, 11:53 PM
Gradual loss of "cooling" performance?
Intermittent?
Still have fam speeds/airflow?
Mode door (defrost / vent / floor) all work correctly?
Manual AC head (3 *****) or Digital head (Lots of buttons)
Old 08-21-2017, 11:56 PM
Combined and deleted your other threads, one thread per subject please......
Old 08-22-2017, 12:16 AM
zxlacxky's Avatar
manual ac. replaced compressor, flushed out lines, evacuated & recharged system.
vehicle has manual ac. I replaced ac compressor, flushed out all lines, replaced all seals, orings evacuated and recharged system. I can't get ac to cool down.
Old 08-22-2017, 08:55 AM
Did you replace the dryer/reservoir? What are the pressures on what temperature day? Could hot water be going through the heater?
Old 08-22-2017, 09:55 AM
If it was intermittent I'd say look at the blend door behind the radio (known issue)
Old 08-22-2017, 10:29 AM
glc is online now
Yes.
Old 09-01-2017, 09:07 AM
Paul888's Avatar
This thread is one of the worst cases of a Thread Hijack I have ever seen. Even the moderator was participating in it.
If the pressures are within specs then I would say it's a blend door problem.
Quick Reply: lack of ac cooling
