Overdrive not working after replacing snap ring and regulator valve!
Old 05-21-2017, 05:18 PM
Ryan Olsen's Avatar
So overdrive stopped working and I read all the forum posts that said replace the snap ring and the overdrive regulator valve, and over drive still is not working, does anyone have any ideas of what might still be the problem
2004 f150
2wd
4.6
Old 05-21-2017, 06:17 PM
Darrin Burch's Avatar
A highly educated guess would be that you missed the pocket on the OD band with the pin on the OD servo.
D
Old 05-21-2017, 06:25 PM
Ryan Olsen's Avatar
D
I did not take out the servo so I'm fairly certain that it is in the band. Unless it can slip out somehow when pushing on the servo.
Old 05-21-2017, 06:29 PM
That would make the next most likely possibility that there is a piece of junk stuck in the valve body somewhere.
D
Old 05-21-2017, 06:43 PM
Ryan Olsen's Avatar
D
That's what I thought but I cleaned it out and I have a whole snap ring. but ill take it apart again next weekend and look. are there any other valves that contribute to overdrive other than the regulator valve?
Old 06-04-2017, 01:39 PM
mitymerc's Avatar
I agree... you either missed the band pocket with the servo pin OR there is still debrs in the OD servo regulator valve.
