2005 F-150 Electrical? Won't shift out of park
Old 02-20-2016, 08:01 PM
moodyjs's Avatar
Hopefully someone can point me in a direction because after pouring over these forums and dismantling my steering column, I'm stuck.
Yesterday I got in my truck and it wouldn't shift out of park. A few quick searches and I was able to locate the button to manually engage the brake shift activator and drive home, however I had no turn signals, but my brake lights were functioning. When I had time to actually look into the problem yesterday, it had resolved itself, everything worked fine again.
This morning, same issues. After research, checking fuses and lights, I assumed my actuator was faulty so I removed it. With direct power it works fine.
Only other clue I have is with power on, my turn signal indicators are both lit solid as is my high beam indicator. Neither lights are actually on and turns signals don't function. If I switch on my headlights, high beam indicator goes off and then indicator comes on if I click on high beams. Without power hazard lights function properly.
I would consider changing the brake light switch, but when I disconnect it, the turn signals and high beam light stay lit, so I'm thinking an electrical "hiccup" somewhere?
Ideas??????????????????????
Old 02-21-2016, 04:17 PM
moodyjs's Avatar
One other symptom, steering wheel does not lock with ignition off.
Old 02-21-2016, 06:14 PM
Gordon M.'s Avatar
Possibly it's The Multi Function Switch (Turn Signal Switch)
Old 02-23-2016, 10:02 PM
aperkins's Avatar
shifter linkage cable? from shifter to tranny?
Old 04-06-2016, 11:54 PM
Mathew Bodinus's Avatar
Hey bud, I have this EXACT same issue as of today. Were you able to figure out the fix?
Old 04-07-2016, 10:39 AM
aperkins's Avatar
Try your PCM plug, see if it's loose... check battery grounds?
Old 04-15-2016, 09:28 AM
Todd Co's Avatar
That's a common cause and would be the first place I start. The clip holding the shift cable to the bracket on the transmission is known to fail and fall off.
Old 04-15-2016, 11:12 AM
projectSHO89's Avatar
His symptoms were of a defective ground circuit but he never returned to report what happened.
if your symptoms are EXACTLY the same, check the grounding studs behind the passenger and driver's kick panels. If they are not EXACTLY the same, then clarify the symptoms.
Neither are possibilities, either would manifest in different symptoms.
If that were to happen, the shift lock override function would also fail.
Old 12-11-2016, 09:34 AM
JTistle1's Avatar
Same issues here, I think I found the problem. 😶
Attached Thumbnails 2005 F-150 Electrical? Won't shift out of park-20161211_090626.jpg
Old 12-11-2016, 12:29 PM
Ouch. Extra ventilation, there, it seems.
Old 12-11-2016, 04:34 PM
JTistle1's Avatar
Just need to fill it with expanding foam, and drill a new hole. 😎
Old 12-15-2016, 02:06 AM
Blue_Blood's Avatar
Had the same issue, that at times I was able to temporarily fix by manipulating the brake module (didn't know about the override). End of the day had to have the shifter assembly replaced under warranty.
Old 09-27-2018, 05:11 PM
theleon's Avatar
same problem
I have the Exact same thing happening now. I checked the ground lugs and they look fine, anything else I can try?
Old 05-19-2019, 07:44 AM
ben michaud's Avatar
Wont shift out of park
I have a 2004 f150 with a simular issue. It wouldn't shift out of park with the headlighys on. Turn off headlights and I would although my heater didn't work just right. Turn on. The lights and shifter was stuck and no signal lights . the fix was a faulty ground on the passengers side where the fuse box is by the passengers feet there is 3 wires that go into one connector and screw into the cab of the truck I cut the wire put on a new connector and sanded the cab to give it a better ground and it works fine. So start there hope it helps
Old 05-19-2019, 05:50 PM
theleon's Avatar
That fixed it! thanks!
Quick Reply: 2005 F-150 Electrical? Won't shift out of park
