paint scheme suggestions?
Old May 14, 2002 | 11:38 PM
  #46
SPROCKET_X's Avatar
Macgyver your truck looks great...good choice on colors and style of the 2 tone.
Old May 15, 2002 | 07:48 AM
  #47
Macgyver's Avatar
thank y'all for the compliments . . if ya need any tips/pointers anyone just ask i'll do my best to answer them
Old May 16, 2002 | 08:17 PM
  #48
inski21's Avatar
what did you use to clean the surface inbetween sandings?
Old May 16, 2002 | 09:41 PM
  #49
Macgyver's Avatar
just took a clean soft bristle wash bush and washed with only water. dont wash with soap it'll leave a residue. also hose down the floor when painting it'll keep the dust down .
Old May 16, 2002 | 09:56 PM
  #50
inski21's Avatar
To do the fade, did you just do both at the same time? and let them over lap? How many coats of the darker color compared to the lighter color?
reducer; is that for getting the right consistancy?
hardener; how much, say per qt of paint, do you mix in?
Did you use clear coat? Sorry for picking your brain.
Old May 17, 2002 | 07:57 AM
  #51
Macgyver's Avatar
each paint manufacture has they're own mixture . omni paints is a 4;1;1 mix . (4 parts paint to 1 part reducer and 1 part hardener ) the silver i paint on the complete truck first (3 coats)
then i came back and did the darker color on the nose (3coats where it is the darkest ) and started with my 8 inches away from the surface and by the time i was to where is fades out i was like 18 to 20 inches away from the surface . omni paints are a SINGLE STAGE paint . what that means is it has properties to give a high gloss shine with out clear coat .you dont have to clear coat it but you can if you want to . the metalics i bought were POLY paint . which means they have alot of transparent or clear properties to alllow the metalic particals to show through. reducer is to thin it out to make it sprayable. then mixing cups i get have the markings on them for the right mixes .
Old May 17, 2002 | 09:50 PM
  #52
inski21's Avatar
Thanks. You are the paint guru.
Old May 18, 2002 | 01:58 PM
  #53
Macgyver's Avatar
well i had taken off and cleaned the lund super steps this past week . painted them at lunch on friday . got them put back on this morning . had done the grill earlier in the week . so it is all completed now
