phenolic spacers for manifolds
do these work? i stumbled upon these on the trick flow website and saw that they make some for ford truck 5.0 applications. are they worth the money? which one works better, the 3/8" or the 1" spacer? they look like an easy upgrade. any input? thanks!
http://www.trickflow.com/product/phe...ic_spacers.htm
They don't do much performance wise on fuel injected engines.
https://www.f150online.com/forums/sh...threadid=64556
They may help prevent intake leaks, though, if used a a very thick gasket
I have a related question, figured I'd post it in this thread:
I assume you guys are talking about spacers going between the TB and the upper intake manifold.
Has anybody tried a spacer (available from Ford Racing) between the upper and lower intake manifolds? I think the theory is that it allows for a cooler air/fuel mixture.
later
scott
later
scott
the one im talking about goes between the upper and lower intake manifold (check out the web page i posted). it has been proven that the ones between the manifold and tb dont help performance.
I've never heard of anyone gaining any noticable power from adding one. The main reason they are used is so that the taller valve covers, needed when adding roller rocker arms, will fit without hitting the intake.
Take care,
-Chris
Take care,
-Chris
Neal's last post in the quoted thread applies to the spacers between upper and lower intake, I'd say.
Yeah, this is what threw me off:
"I took my POWERAID spacer and had the spiral machined out of it, and t hen polished it. I installed it on my truck at the dragstrip and got NO gain what so ever. No better throttle responce or anything"
By Neal in bjoern's link. Sorry for the confusion, guys. Anyways good input as I was considering a phenolic spacer on the ol' 302
later
scott
later
scott
