89 E4OD Shift problems
Old Oct 2, 2018 | 06:04 PM
Michael Gibbs's Avatar
89 AOD Shift problems
I have an 89 Ford F150 With the 302 and AOD transmission. i was sitting at a light an i poped a leak in the rear of my pan and the extension housing gasket bad enough that it would not drive. i changed the filter and gaskets. now it wont shift past 2nd gear. I changed the TPS after reading the codes but it still will not shift past 2nd. i know there is a limp mode in the newer style Trucks is there one in the 89. or does anyone have an idea as to what might be causing it. before the leak i had no shift issues what so ever this is my daily driver so i need it back on the road asap
Old Oct 2, 2018 | 08:19 PM
Hate to say it, but running it low on fluid might have toasted it.
Let's see what other folks have to say. I sure hope it's a simple fix, but it sounds like it's due for a rebuild.
Old Oct 2, 2018 | 08:24 PM
I was kinda figuring that. Just was hoping not to have to.
It wasn't low on fluid when the gaskets went and I shut it down right after they blew and had it towed home.
Old Oct 2, 2018 | 08:25 PM
How many miles on it?
Old Oct 2, 2018 | 08:29 PM
According to the previous owner 175,000+
Old Oct 2, 2018 | 08:33 PM
That's a respectable amount of mileage. Do you know if they changed the fluid once or twice?
Old Oct 2, 2018 | 08:35 PM
The fluid that came out was black as night. But there were no shavings or chunks in the pan and there was no sparkle to the fluid that's why I hoped it would be ok.
Old Oct 2, 2018 | 08:51 PM
Eh, that don't sound good.
Let's see what other folks say. I know some on here are familiar with the AOD.
Old Oct 2, 2018 | 11:53 PM
Rebuild time.
