1992 f150, 5.0 not starting
Old Jan 21, 2011 | 08:06 PM
F150Swartz's Avatar
my brother has a 1992 f150 flareside with a 5.0L, it wont start, cranks over no problem, sputters and half assed fires but thats it, any help would be awesome, thanks!
Old Jan 21, 2011 | 08:13 PM
F150Swartz's Avatar
and doesnt start when you spray fuel into the throttle body either...
Old Jan 21, 2011 | 09:17 PM
NASSTY's Avatar
Can you hear the fuel pump prime when you turn the key to the on position?To listen for the pump priming don't turn the key all the way to the start position, just to the on position.
Old Jan 21, 2011 | 10:07 PM
F150Swartz's Avatar
ya pretty sure i can hear it
Old Jan 21, 2011 | 10:41 PM
masseyman's Avatar
Your next step would be to check if you are getting spark through the spark plug wires while cranking the engine over.
Old Jan 22, 2011 | 01:36 AM
Steve83's Avatar
Don't double-post.
https://www.f150online.com/forums/v8...ml#post4468728
Old Jan 22, 2011 | 09:57 AM
rebranger's Avatar
I too have the same problem on a 96 150 with 4.6 L six cyc, auto. Engine turns over fine, fuel pump running, can smell gas from exhaust, no fire! Checked all fuses, even under hood, all OK, got to be a MODULE or relay gone bad somewhere. Truck was running fine when I parked it overnight!
Please Help STRANDED!
Old Jan 22, 2011 | 02:08 PM
Steve83's Avatar
Don't hijack or double-post. Your truck is different - keep it in your own thread in this forum.
Old Jan 22, 2011 | 08:03 PM
F150Swartz's Avatar
well i figured it out, it was exactly what i thought in the first place..... plugs.... he had my dads friend look at it the other day and he said "it has spark so no its not the plugs".... hah, fixed, runs fine
