What is the best way...
Old Apr 9, 2010 | 12:19 AM
OREGONMUDDER's Avatar
What is the best way to eliminate the catalytic converter on a 96 F150. I reside in an area with no EPA testing and the cat is on its way out... service engine light on for the rear heat sensor just behind the cat. I just would like to get rid of it any easy solutions? any gifted shade tree engineering? I would love to do a full strait from the headers set up - to a Flowmax muffler, but for now money is tight so.. something simple will have to do.
Old Apr 9, 2010 | 12:42 AM
Lindenmooch's Avatar
cut it off? replace with straight pipe? seems simple enough.
Old Apr 9, 2010 | 06:50 AM
Drop the pipe down and ream the guts out.
Old Apr 9, 2010 | 12:54 PM
ymeski's Avatar
If you mean you have a o2 after the cat that's coding, they make a simple kit that makes the ECU think the sensor is reading at close to perfect fuel trim (14.68 to 1) so the ECU "thinks" the Cat is still there & doing a great job! o2's ahead of the Cat are the ones that actually control fuel trim. Behind the Cat is just monitoring Cat health. Doe that help?
Old Apr 9, 2010 | 03:18 PM
StrangeRanger's Avatar
The fact that your post-cat HEGO sensor is showing a code does not mean your cat is dying. It simply means that the engine is running off ratio. There are many possible causes and a cat failure is among the least likely
Old Apr 12, 2010 | 02:57 AM
I was under the presumption that all issues with O2 sensors behind the cat were cat issues.. How might I get the engine running on ratio?
Old Apr 12, 2010 | 05:27 AM
What error codes do you have?
Old Apr 16, 2010 | 12:18 AM
MI02SVT's Avatar
one way to test if the cat is going bad is use a temp gun and check the temp of the pipes just before and after the cat if the temp is about a 50 degree difference it should be good if not its probably getting clogged
or use a rubber mallet and tap it and if you hear rattling the catalyst is broken up inside
its a 96 so the o2 sensor does monitor the cat and the emissions from the vehicle it was madated for all 96 and newer vehicles
either way im not too much of a fan anyway i say cut it off and straight pipe it too
