Detonation clatter-help getting rid of
95 5.0 2wd auto 3.08 rear. 195k
She now runs , shifts, and brakes nice and smooth. About the last thing that I'd really like to eliminate would be what I assume is detonation under full throttle (I drive like grandpa but sometimes pass and freeway merging).
The PCV, EGR, O2, catalytic converter are all orginal (not changed).
I've set the timing to 10btdc, cleaned the TB, and MAF (helped alot).
She seems to respond to 97 gas
Will changing the above sensors/valves help?
What you all recommend?
I've read some about the seafoam vac line deal but it makes me a little nervous-could the detonation come from a load of carbon build up?
Thanks for any info.
Thanks for the reply. I changed the PCV yesterday, pulled the EGR and scrubbed it out with brake cleaner and was amazed to find that most of the hard downshift clatter had disappeared!
I'll go ahead with the o2 also though, cause by now it's probably registering oxygen from the rust process instead of the exhaust.
Thanks for the help!
Toss the rest in the tank, unless your planning on changing the oil in the near future. If you are, 1/3 in tank, 1/3 in oil. You will immediately have a smoother idle & better throttle response. (and less detonation) With your condition, you may want to do a whole bottle in the tank. http://www.youtube.com/watch?v=zt_oX...eature=related This shows how to for Carbed, & EFI.
Have you tried Stock Motorcraft Nic plated copper core plugs? They produce less combustion chamber temps. than Platinum's! Their only drawback is they don't last 50K miles & they don't self clean (by producing a drastically higher temperature) But if your plugs are fowling, wouldn't you like to know about it? And I like to look at my plugs more than once every 50K anyway. It would be a $15 experiment + elbow grease.
yep tried them and no difference, in fact I still have them but I did put the platinums back in. I am fixin to put on headers, I bought the Ford Racing shorties. The manifolds I could find were junk so I elected to put the headers. I will find out if these will help my problem or not. Next I guess I will start throwing parts at it. The truck feels like I am towing just to take off. Its not near as bad when its warmed up and been dirving around but it still does not have the power I think it should have.
Many times a repair shop will retard base timing to like, 8 BTDC to try to bury a ping problem. One side effect is poor acceleration from a stop because the timing curve is now farther up the RPM range. I remember the beginning of your adventure w/ this. The only bear we couldn't kill. Seems like only yesterday, but it sure aint! Good luck! If you ever figure it out, let us know. I (we) threw every trick I had in my bag at it! Still in the same line of work?
yep still the same. I have tried retarding the timing but it does make it more sluggish than it is. I think my next step is Im going to have the injectors professionally cleaned and balanced. I found a place around her that does all 8 for like 200 bucks. I have to remove them and reinstall but they only have a one day turn around. I figure with 180k it needs it anyway
Might want to consider replacement. Test pressure bleed down time, w/ a pressure gauge on the fuel rail. Maybe some are cracked. Cleaning won't help that. Ask them to consider that. Having to replace them on top of cleaning would be good for them, but not so good for you! Something's defiantly wacked, because you should be able to run 14 BTDC w/o a problem, and as you know, you sure couldn't do that now. Probably a little sketchy at stock 10 BTCD base time. I'm leaning towards an injector problem, but exactly what's the problem? If rail pressure bleeds off slowly, a cleaning is in order, If it drops off like a rock, your probably looking at injectors that are compromised.
Running super redundantly in that engine can do it all by itself. After a period of time, it wont run w/o it. This ping problem's been going on for a long time, & he hasn't had much of a choice, needing the truck for transo. Have you done a fuel pressure check w/ bleed down?
no I have not. I have not had time. I didnt drive it much before. I have a take home car issued to me. I have thought about the fuelpressure test but have noot had the time lately. my son in law has been driving the truck. I am waiting for him to get his car back
Where can that motorvac - bg be done
